torque numbers for CRVTEC Turbo.
I'm currently in the process of rebuilding a crvtec dart block turbo set up. I need to torque the bolts of the internals. I need to find the torque numbers for the whole internal set up. I for surely need them for the crank/pistons/bearings!!
I've searched and could not find anything as everyone asks about Torque stuff. PLEASE help me and point me in the right direction where I could find these numbers.
Head is a b16, bottom end is a b20 dart block 84.5mm.
Please help!! Thanks!!
what studs are you using ARP hardware aftermarket or stock rods mostlikely if you have dart block u are using ls crank i am assuming what is your specs yuo need to give the information so then we can assist with torque values.
Mains stock or ARP or GE what brand main studs you using
Rods What name and what bolt you have on it
Head studs what spec and hat brand each one has its own yield value
studs should have came with the torque reading based on either oil or arp assembly lube.
the eagle rod 3.8bolt or 5/16 bol varies in torque value which one do you have.
