too much oil bad?
Old Mar 3, 2004 | 09:19 AM
See Are X's Avatar
Default too much oil bad?
I accidently put too much oil in my car when I changed it...theres about a quart extra in there...is that bad? should I drain some of it out?
Old Mar 3, 2004 | 09:29 AM
purplegsr's Avatar
Default Re: too much oil bad? (See Are X)
Yeah, an entire quart extra can be bad. If the dipstick has any oil above the 2nd dot, then you need to drain it to that line or below.
Old Mar 3, 2004 | 11:20 AM
99b18's Avatar
yes this can cause too much crankcase pressure. which will blow your oil pan seal.
Old Mar 4, 2004 | 08:14 PM
StorminMatt's Avatar
Default Re: too much oil bad? (99b18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99b18 &raquo;</TD></TR><TR><TD CLASS="quote">yes this can cause too much crankcase pressure. which will blow your oil pan seal.</TD></TR></TABLE>
Actually, the real reason why too much oil is bad is that if it is up to the level of the crank, it tends to get whipped by the crank. This causes foaming. And foamy oil does not lubricate well.
Old Mar 4, 2004 | 08:16 PM
warchild69's Avatar
Default Re: too much oil bad? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, the real reason why too much oil is bad is that if it is up to the level of the crank, it tends to get whipped by the crank. This causes foaming. And foamy oil does not lubricate well.</TD></TR></TABLE>
good call
Old Mar 5, 2004 | 07:13 PM
99b18's Avatar
actually they are both real reasons. thank u for pointing out the second one. no need to be rude though.
John 07
Feb 3, 2007 06:58 AM
teddy_dc2
Aug 10, 2006 06:11 AM
is3oo
Jun 6, 2004 06:49 AM
Infinity_Racer
18
Sep 5, 2003 12:29 PM
Rhetoric
Aug 6, 2003 12:59 AM
