Tips for removing 13 year old header bolts
Old May 9, 2013 | 11:54 AM
Atomic1's Avatar
Default Tips for removing 13 year old header bolts
I need to replace my stock header on my EM1. The last time this header has been off was 13 years ago in japan. I put my long socket wrench on them and they're on there pretty tight. Before I go wild and break off a bolt head and ruin my week, do you guys have any tips? I'm soaking them in PB blaster as I speak. I do have an electric impact wrench, breaker bar, and torch. Not sure which might be a better approach
Old May 9, 2013 | 02:03 PM
MMMGIRL's Avatar
Default Re: Tips for removing 13 year old header bolts
Let them soak in PB for awhile then take out your biggest breaker bar and try. If they dont budge heat them up. If the heat doesnt work though it will help seize it even more when it cools.
Old May 9, 2013 | 03:19 PM
grumblemarc's Avatar
The Grumpiest
IDK but to me something sounds inherently wrong about suggesting heat on an area that is susceptible to warpage due to heat.
Old May 9, 2013 | 03:57 PM
ThE HeLLRaZoR's Avatar
WD-40 and Impact gun!!! I like to use impact if possible because it gives mostly Twist Force on the Bolt/Threads! You use a Breaker Bar and your putting ALOT of force on the Stud!
Heat helps most when there is Loctite involved to break the seal.
Old May 9, 2013 | 04:44 PM
HondaPartsHero's Avatar
Technical Hero
Kroil
Old May 9, 2013 | 05:39 PM
Atomic1's Avatar
Thank you for the replies. I applied two doses of PB over a span of 2 hours, said a prayer, and wow, what a difference. They creaked off with the same long handled wratchet I used before, steady, but firm pressure, cold engine.
Old May 10, 2013 | 07:15 AM
1992Si's Avatar
Next time you put any bolt or nut on the car use anti-sieze compound on the threads.
I have been doing that to all threads for years now. Even the lug nuts.
Old May 11, 2013 | 01:04 PM
Atomic1's Avatar
I'll be sure to tell Honda to put some on mine in the factory next time I order a new car
Old May 11, 2013 | 08:21 PM
vteczone's Avatar
Whats PB?
Old May 13, 2013 | 09:10 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
This will cause you to over tighten the lug nuts....But a good tip regarding exhaust bolts.
Old May 13, 2013 | 05:55 PM
smit7277's Avatar
Originally Posted by vteczone
Whats PB?
PB stands for a brand name called PB Wrench. They also have PB Blaster which is like a strong WD-40. The blaster has a nozzle that shoots the stuff out at a high pressure so it pretty much goes everywhere except where you need it. The stuff works good though. I still like 3-in-one oil...easier to control...2 drops and you're done.
Just1nK4ng
11
Aug 10, 2018 02:41 AM
SiR99
Jan 20, 2008 04:09 PM
MugenHonda
Apr 21, 2006 03:53 PM
BlueFang08
Mar 13, 2004 11:42 AM
stolenhubcabs
Dec 18, 2003 07:09 PM
