trouble taking off header, help please
Old Dec 18, 2003 | 02:20 PM
stolenhubcabs's Avatar
Default trouble taking off header, help please
i am having a very difficult time taking off the #15 bolt with the #13 washer (located at the bottom center of the diagram), it was so tight that it bent my ratchet, i sprayed wd40 on it and everything, any suggestions?
Old Dec 18, 2003 | 02:24 PM
IN VTEC's Avatar
Default Re: trouble taking off header, help please (stolenhubcabs)
Go from underneath and use a 2ft breaker bar and 1/2" drive 14mm. It'll come off like butter. If you snap the head off...no big deal. You won't use it on aftermarket header systems.
Old Dec 18, 2003 | 02:30 PM
Default Re: trouble taking off header, help please (IN VTEC)
i went underneath and used this hollow metal bar to hook onto my ratchet (this was how i got the header bolts off), but the bolt didn't budge, the ratchet bent like crazy and i'll be going to buy a new one soon (in a matter of minutes)
Old Dec 18, 2003 | 02:33 PM
AK94GSR's Avatar
how the hell did u bend your ratchet?????
i would say first get yourself a good set of tools and some pb blaster
but yeah try what invtec said, that should work
FastSS's Avatar
uh its only a 14mil bolt... are you using a 1/4er drive ratchet?
Old Dec 18, 2003 | 02:43 PM
oMek's Avatar
Default Re: trouble taking off header, help please (FastSS)
PB BLASTER OWNS STUCK BOLTS.
thanks, i'm going to the store now to get a new one
Old Dec 18, 2003 | 04:40 PM
EL Vap133's Avatar
From the looks of that diagram, why not just take off bolt #7 and leave that piece there if it doesn't come off?
Old Dec 18, 2003 | 05:14 PM
Cramerox's Avatar
Default Re: trouble taking off header, help please (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">From the looks of that diagram, why not just take off bolt #7 and leave that piece there if it doesn't come off? </TD></TR></TABLE>\
maybe clearance issue with the new header?
Old Dec 18, 2003 | 05:49 PM
DA-MAX's Avatar
stolenhubpcaps, what header did you decide on?? ( I remember you made that post a while back)
Old Dec 18, 2003 | 07:09 PM
Mr. Softee's Avatar
Default Re: (DA-MAX)
use a 10' breaker bar, no joke. thats what i have used on those types of things before, tehy stand no chance.
Just1nK4ng
11
Aug 10, 2018 02:41 AM
Atomic1
May 13, 2013 05:55 PM
JohnQPublic
May 26, 2006 07:15 PM
BlueFang08
Mar 13, 2004 11:42 AM
EF_LSVtec
Oct 3, 2002 06:30 AM
