timing question...need help asap
sohc vtec, i was wondering cause i tried to set the ignitiong timing back to stock, the red mark, and i when i do it, the engine gets hella loud. the red mark is stock timing right? man i need to ge the car dialed in on the dyno, but after i get the stupid check engine light off.
hmm....how can the cam gear be messed up? how can i check to see that its right? i had it installed by a professional. sorry i dont really know much abou this stuff
just cuz they were a pro don't mean crap. I've had to help fix quite a few swaps that the local "pros" did.
Like wiring up a ZC into a CRX Si. About 8 wires at the ECU were hacked. WTF?
with SOHC's (all I work on) if you advance the cam you must RETARD the ignition timing. As you advance the cam, you also advance the ignition timing.
ek4__
Aug 3, 2006 08:15 PM
