TIMING/ DISTRIBUTOR PROBLEM!!!!! CEL!!!
Old Oct 27, 2004 | 09:36 AM
  #51
EE_Chris's Avatar
Default Re: (JimBlake)
Perhaps I described it 'wrong' - but it seems we're saying the same thing.
The ignitor is simply the switch that the ECU uses to control charging the primary coil. If the ECU sends +12v to the ignitor (Yel/Grn wire), the 'switch' is closed and the primary coil is charging. When the ECU pulls the Yel/Grn wire to ground, the circuit is open, as you described, and the primary can now discharge into the secondary coil.
So I agree - sorry if I was a tad misleading.
Old Oct 28, 2004 | 11:57 PM
  #52
WrongWD's Avatar
well, i tried grounding out a13, nothing happened. changed out CEL bulb, nothin. ill work on the distributor tomorrow
Old Oct 29, 2004 | 03:48 AM
  #53
JimBlake's Avatar
Default Re: (WrongWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD &raquo;</TD></TR><TR><TD CLASS="quote">well, i tried grounding out a13, nothing happened. changed out CEL bulb, nothin.</TD></TR></TABLE>Check whether the bulb is getting battery voltage on it's other terminal (the one that doesn't go to A13). Maybe something warped & doesn't make contact in the cluster?
If you want to check trouble codes, set your DMM for continuity check. One lead on ground, other lead stuck into the back of A13 while it's plugged into the ECU. It'll show continuity (beep) when it's trying to turn on the light.
Just in case any other wiring is farbed up, D4 is the service check connector. Shorting that one to ground is the same thing as jumpering the SCC with a paperclip.
Old Nov 1, 2004 | 10:38 AM
  #54
zm_dawg's Avatar
u get your car started or what
Old Nov 1, 2004 | 11:39 AM
  #55
WrongWD's Avatar
not yet, just had midterms, so back to work!
guy in a jetta
Nov 7, 2017 12:05 PM
dudesmccool
11
Dec 30, 2015 01:55 PM
88LsRex
May 29, 2012 03:41 PM
badger64
Feb 21, 2008 11:53 PM
chad
Oct 6, 2003 04:56 PM
