Timing belt issue
Old Dec 9, 2006 | 12:04 AM
hondasniper's Avatar
Default Timing belt issue
I have a H22A4 and I have never had this problem before when I install timing belts on any car. When I turn the car on, the timing belt keeps creeping outwards away from the motor. I called Greddy, but they told me that the tensioner isn't tight enough. I tightened it to the max, still does it. If I tighen it any more, it'll snap. I was thinking a tensioner pulley issue. Any inputs???
Old Dec 9, 2006 | 07:06 PM
PrettyLude's Avatar
you can't really tighten up the autotensioner, but if you have a manual tensioner it has to be something is still loose
Old Dec 10, 2006 | 01:41 PM
Default Re: (PrettyLude)
well, i do have the auto tensioner, but when i take off the bracket to release the auto tensioner, it doesn't tighten up all the way. So I go underneath with a rod and press up against the pulley to tighten it up a little bit. Greddy says to tighten it up some more, but it doesn't help. I have done plenty of timing belts on hondas, even on other h22s and i haven't ran into this problem before. I'll check again to make sure everything is tight.
Old Dec 10, 2006 | 02:20 PM
Brick Top's Avatar
Default Re: (hondasniper)
did you put the belt washer on before the crank pulley? it guides the belt to stay in place.
Old Dec 10, 2006 | 10:34 PM
Default Re: (brick top)
Are you sure the H22A4's have them??? He had an issue and had some other people work on it before. When I took everything off, there wasn't one on there. I didn't think the H22A4's had them since the pulley has a built on washer that is used for the crankshaft position sensor.
Old Dec 12, 2006 | 11:00 PM
I took off the balancer shaft belt and pulley and I put all the pulleys back on the crankshaft w/o the timing cover on. I disconnected the coil and distributor and took the valve cover off. I turned the motor over and when I did that, the problem is the tensioner pulley. It starts to fall off there and goes back to normal right at the water pump. I'm waiting on the tensioner pulley now.
Old Dec 16, 2006 | 06:57 AM
installed new tensioner pulley. Fixed the problem. another hapy customer.
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
d124g0n
Dec 28, 2005 12:49 PM
PrecisionH23a
Aug 14, 2002 09:22 AM
PrecisionH23a
Aug 14, 2002 05:16 AM
