TICKING nooise
Old Oct 16, 2003 | 08:19 PM
LBDM EK97's Avatar
Default TICKING nooise
ok yesterday i accidently over revved my b20 and then it started to have a quiet tick..by time i got home it got louder..does anyone know what the problem really is and how much it should cost me to fix it?? thankss
Old Oct 16, 2003 | 08:26 PM
chrisCNL's Avatar
Default Re: TICKING nooise (LBDM EK97)
if you had overrev your motor it might be that the nuts on top of the rocker arm cam loose. to make sure use a 3/8 extension and put one end to your ear and move teh other end along the top of the valve cover while the motor is on idle. if you need any help im me.
Old Oct 16, 2003 | 08:47 PM
PhatOptimo's Avatar
Default Re: TICKING nooise (chrisCNL)
You need to find where the ticking is comming from first. Is it the upper or low portion of the engine?
Old Oct 16, 2003 | 08:59 PM
LBDM EK97's Avatar
i think its comming from the head..
Old Oct 16, 2003 | 09:09 PM
Kataku2K3's Avatar
Default Re: (LBDM EK97)
Could have bent a valve... I'd do a valve adjust first, see if it makes any difference... If not then I'm guessing you bent a valve, you can double check this by running a leakdown test... Any air leaking coming out of either the IN/EX manifold would indicate bent valves... Just my $0.02, Good Luck
si90rex
Sep 15, 2011 07:21 AM
oh_dam
Feb 16, 2010 12:57 PM
rotascircuit
Dec 16, 2009 02:58 PM
Ryanwill86
Jan 14, 2009 06:04 PM
SiCRX90
Nov 6, 2005 06:15 PM
