Throttle positioning sensor (Cel 7)
Old Dec 24, 2007 | 06:46 PM
Paul-eg's Avatar
Default Throttle positioning sensor (Cel 7)
Hey,
I have been getting a CEL7 which is TPS.... on my jdm b18c eg I replaced the TPS with one I got off my friend from a D series. I installed it got it all dialed it to oem specs. I didnt use a gasket because I couldent find one but i have heard you dont need them. One week later im getting the same code. I checked all the wiring going to the ECU all looks good. The CEL is not always on. On some trips it comes on... on others it doesnt. You thing I just got a shotty TPS? What could I try? Should I just buck up and get a new tps from some b series at honda?
Thanks
Paul
Old Jan 3, 2008 | 10:33 PM
Paul-eg's Avatar
Default Re: Throttle positioning sensor (Paul-eg)
TTT looked at it christmas eve tried a different ECU which came up with more codes put my old one back on today( one week later) i get the same code. CEL 7??? Ideas?
Old Jan 4, 2008 | 07:52 AM
thesmogman's Avatar
You eliminated the TPS itself so on to the wiring...
Check the connectors, and for wires that have been abused(Bent all which-a-way) and such.
Backprobe the ECU connector so you can see what the ecu is seeing and move the wires/connectors.
That is the next step anyway.
BoostAndBoobs
Apr 21, 2016 04:53 AM
Horseofcourse
Apr 28, 2008 07:44 PM
Paul-eg
Dec 25, 2007 01:31 AM
elips0id
Apr 16, 2005 08:30 AM
Lowez
May 30, 2002 07:06 PM
