throttle angle sensor question d16a6
Old Mar 26, 2008 | 05:05 PM
Magic Wheels's Avatar
Default throttle angle sensor question d16a6
i put zc or pm7 pistons into a d16a6 block. i started the car and the check engine light came on. looked at the ecu and is blinking 7 times. telling me that is the throttle angle sensor. i turn the ignition switch off. removed the hazard fuse to reset the ecu, still on. what could it be. any suggestion. thanks.
Old Mar 26, 2008 | 08:18 PM
rdssk8rcs1's Avatar
Default Re: throttle angle sensor question d16a6 (Magic Wheels)
Cant be related to your piston install. Check for any damage to the wires or clips during the modification.
Old Mar 27, 2008 | 09:47 AM
it's the tps. removed the rubber cover that comes with it and it was cracked, wet and rusted inside. so, you guys knows what that mean.
I NEED A TPS ASAP. Chesapeake area. Thanks for all replied.
Old Mar 27, 2008 | 04:32 PM
Found one tps. thanks.
Old Mar 27, 2008 | 04:50 PM
rdssk8rcs1's Avatar
Good to hear
cranker
Jul 15, 2010 03:22 PM
geogal84
Oct 23, 2007 02:41 PM
Orangedragone
18
Sep 14, 2006 02:52 PM
dc2integtypR
Oct 5, 2005 11:02 PM
MassScene
Apr 27, 2004 05:08 PM
