throttle angle sensor question d16a6
i put zc or pm7 pistons into a d16a6 block. i started the car and the check engine light came on. looked at the ecu and is blinking 7 times. telling me that is the throttle angle sensor. i turn the ignition switch off. removed the hazard fuse to reset the ecu, still on. what could it be. any suggestion. thanks.
it's the tps. removed the rubber cover that comes with it and it was cracked, wet and rusted inside. so, you guys knows what that mean.
I NEED A TPS ASAP. Chesapeake area. Thanks for all replied.
MassScene
Apr 27, 2004 05:08 PM
