threads in transmission casing are stripped... need help to tap
Old Oct 9, 2003 | 03:47 AM
The Internet Tough Guy's Avatar
Default threads in transmission casing are stripped... need help to tap
argh. long story short: replaced the right front lower transmission mount bracket on my 96 civic w/ aftermarket one. instructions were wrong (61 lbft, helms says 47), over torqued bolt & threads on inside of transmission stripped . i need to retap it & have never done this before. what do i need, anything else besides drill, drill bit, tap & cutting oil? also, its a 12mm bolt, so should i get a 13mm drill bit? what size tap would i need? please help me
Old Oct 9, 2003 | 04:24 AM
JimBlake's Avatar
Default Re: threads in transmission casing are stripped... need help to tap (jwn7)
I'd get a HeliCoil kit.
Old Oct 9, 2003 | 05:29 AM
Default Re: threads in transmission casing are stripped... need help to tap (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I'd get a HeliCoil kit.</TD></TR></TABLE>
ok i did a search on heli coils.. all i do is buy a kit w/ the drill bit, tap, and coil spring. then drill the hole out, tap it, put the coil thingy in, and then screw the original bolt in right? if thats it, anyone know where i can get a kit for a 12mm bolt?
Modified by jwn7 at 10:10 AM 10/9/2003
Old Oct 9, 2003 | 07:23 AM
1fastVX's Avatar
Well first off NAPA auto parts sells the Helicoil kits which include everything but the drill bit and tapping oil..you can usually buy those also at NAPA...make sure you buy the EXACT drill bit the Helicoil kits specifies. I did my intermediate shaft bracket that bolts into the engine with the Helicoil and so far it is working great!!
PS....I have also heard that Timesert's are a better insert than Helicoils....you might want to check them out too?
Old Oct 9, 2003 | 07:36 AM
sleepyEK's Avatar
Default Re: threads in transmission casing are stripped... need help to tap (1fastVX)
same here, helicoils have saved me more than once.
Old Oct 10, 2003 | 06:17 AM
Wes V's Avatar
Default Re: threads in transmission casing are stripped... need help to tap (sleepyEK)
I just wanted to repeat the comment a couple posts ago;
You HAVE to use the exact size drill called out in the kit!!!!! Plan on getting one from a shop that sells machine shop stuff. It's normally a size that isn't stocked by places like auto parts stores or home depot.
Wes
Old Oct 10, 2003 | 09:10 AM
bruthaboost's Avatar
Get the time serts. I've picked up an engine blocks with stripped bolt holes for the motor mounts and tranny. The timeserts use a nice sleeve and when you look at their design, trust me your mind will be put a ease as far as their torque holding capacity goes.
Jeff
Old Oct 10, 2003 | 09:34 AM
spaceman's Avatar
Default Re: threads in transmission casing are stripped... need help to tap (Wes V)
(wes v)where in winnetka r u?what streets...i used to live there for a while
thrty8street
Aug 28, 2015 04:29 PM
hmtcrxsir
Nov 7, 2005 01:02 AM
0evilEMPIRE0
Oct 15, 2004 02:23 AM
Heavy Pee
Oct 2, 2002 05:41 PM
