These Rods still good? (Big pics)
Old Dec 9, 2003 | 08:30 AM
mattjohnston's Avatar
Default These Rods still good? (Big pics)
Rod
Rod
Old Bearing
Crank Journal
Obviously the bearings are pretty worn. But are the rods, and crank still ok?
Thanks!
Old Dec 9, 2003 | 11:08 AM
JDogg's Avatar
you'd have measure the crank to tell if it was still good. imo i wouldnt use that rod. if you did it would have to be cleaned up and probably thicker berings used
Old Dec 9, 2003 | 11:30 AM
b18bturbo's Avatar
Default Re: (JDogg)
yeah i would use those rods as well looks to be heavly scarred
Old Dec 9, 2003 | 03:35 PM
Kendall's Avatar
Measure everything, and double check it. You may have to have work done to either the rods, the crank, or both. If you do, then you will need thicker bearings.
orioncivic
Aug 15, 2012 04:36 PM
r1de4life
Mar 26, 2008 02:57 PM
Bc3
Dec 26, 2006 11:35 AM
love2xlr8integra
May 2, 2004 08:00 PM
paulzy
Dec 22, 2001 10:41 AM
