Is there a diff. in obd1 & obd2 Oil pump?
Old Jan 20, 2004 | 11:16 AM
TypeGSR196's Avatar
Default Is there a diff. in obd1 & obd2 Oil pump?
I want to know if buying a used 98+ would be ok or do I have to buy a new one from dealer which is an arm & a leg............
Thanx in Advance
Old Jan 20, 2004 | 11:26 AM
b18bturbo's Avatar
Default Re: Is there a diff. in obd1 & obd2 Oil pump? (TypeGSR196)
yes ther is a difference between obd 1 and obd 2 pumps the obd 2 pumps ahve the position for the CYP sensor and also the lower cover has different mounting holes
Old Jan 20, 2004 | 11:35 AM
TypeGSR196's Avatar
Default Re: Is there a diff. in obd1 & obd2 Oil pump? (b18bturbo)
so in other words I can't use an obd2 on a obd1 block, thanx dude
Old Jan 20, 2004 | 12:14 PM
mmuller's Avatar
Mad Scientist
yes you can, but you have to get a obd2 lower timing cover also.
Old Jan 20, 2004 | 01:32 PM
3rdGteg's Avatar
Default Re: Is there a diff. in obd1 & obd2 Oil pump? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yes you can, but you have to get a obd2 lower timing cover also.</TD></TR></TABLE>Have anyone tried this? obd2 pump bolts up to obd1 block w/ just the addition of the lower timing cover?
Old Jan 20, 2004 | 02:11 PM
irev210's Avatar
Default Re: Is there a diff. in obd1 & obd2 Oil pump? (3rdGteg)
yes it works just fine
Old Jan 20, 2004 | 04:28 PM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">yes ther is a difference between obd 1 and obd 2 pumps the obd 2 pumps ahve the position for the CYP sensor and also the lower cover has different mounting holes</TD></TR></TABLE>
It's the CKF sensory not CYP.
-PHiZ
Old Feb 10, 2004 | 10:12 AM
3rdGteg's Avatar
Default Re: Is there a diff. in obd1 & obd2 Oil pump? (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">yes it works just fine</TD></TR></TABLE>So an obd2 oil pump will bolt up to an obd1 block with just the addition of the lower timing belt cover......so did you guys change out the water pump, timing belt, etc. to the newer obd2 ones also (because the obd1 and obd2 parts are different) when using the new obd2 oil pump, or just kept everything else the same besides the oil pump and lower timing cover?
Old Feb 10, 2004 | 10:38 AM
vtecb20coupe's Avatar
B A N N E D
no, you shouldn't have to change anything else out for the obd difference.
Old Feb 10, 2004 | 11:16 AM
Kataku2K3's Avatar
Default Re: Is there a diff. in obd1 & obd2 Oil pump? (vtecb20coupe)
As everyone has said the oil pumps have the exact same mounting points (i.e. both will bolt to the same block without a problem) the difference is the '96+ oil pumps have mounting points on their outer casing for the crankshaft speed fluctuation sensor which is only needed when running most OBDII ECU's... Whenever we rebuild motors we typically just use OBDII oil pump even if the motor is going in an OBDI car, it just makes it easier if later on down the road your motor gets paired up with an OBDII ECU...
Old Feb 10, 2004 | 11:38 AM
3rdGteg's Avatar
Default Re: Is there a diff. in obd1 & obd2 Oil pump? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">As everyone has said the oil pumps have the exact same mounting points (i.e. both will bolt to the same block without a problem) the difference is the '96+ oil pumps have mounting points on their outer casing for the crankshaft speed fluctuation sensor which is only needed when running most OBDII ECU's... Whenever we rebuild motors we typically just use OBDII oil pump even if the motor is going in an OBDI car, it just makes it easier if later on down the road your motor gets paired up with an OBDII ECU...</TD></TR></TABLE>Thanks for making that clear, just wondering if there was a difference in the teeth, etc. But I got it now, thanks
Old Feb 10, 2004 | 12:08 PM
Kataku2K3's Avatar
Damn, I just remembered too... I forgot to mention even if the water pumps for some reason have a different part number they're still the exact same... 22 teeth = VTEC pump
MikeD21
Feb 12, 2019 08:30 PM
CivicTT
Jul 12, 2010 01:29 PM
Integra_Nguyen
Jul 8, 2006 10:16 AM
AsianMullet
Jan 22, 2005 05:21 PM
blackeg
Oct 12, 2004 03:12 AM
