testing injectors: peak & hold or saturated?
Old Oct 10, 2005 | 08:08 PM
Keith Pierson's bitch's Avatar
Default testing injectors: peak & hold or saturated?
I purchased some precision 450's and the person wasnt sure if they are peak and hold or saturated... is there any way to test them?
Old Oct 11, 2005 | 03:45 AM
jmcclell's Avatar
Default Re: testing injectors: peak & hold or saturated? (xxturbodreamsxx)
Measure the injector coil resistance with a multimeter.
2-3 ohm coil - Peak-and-hold injector
12-14 ohm coil - Saturated injector
Old Oct 11, 2005 | 08:11 PM
ok thanks man... is one better than the other for turbo? i've heard that for anything under 14 lbs it doesnt really matter?
Old Oct 11, 2005 | 09:02 PM
SOHCmaster's Avatar
Low ohm is peak and hold High ohm is saturated. You dont need peak and hold unless your going over a 660 injector then its best to convert over.
Old Oct 12, 2005 | 03:21 PM
Mirage's Avatar
You can make either work, just make sure that your electronics can drive them. If they are P&H you *MAY* need to get a resistor box or a P&H injector driver module.
Old Oct 16, 2005 | 09:26 AM
ok sweet, well off to get the car tuned and see how much power i can make
b18 hatch mike
Oct 5, 2010 05:59 PM
f1 vtec
Feb 16, 2006 07:57 AM
joeyitr309
Apr 22, 2005 08:07 AM
rtpassini
Nov 16, 2004 07:40 PM
PanamaVTI
Jan 21, 2004 12:14 PM
