Test for Vtec
Old May 1, 2005 | 05:25 AM
txq45's Avatar
Default Test for Vtec
What is the way to test the selnoid and the pressure sensor on a Vtec engine.. just did the swap (89 SI to 93 D15 Vtec with harness cross-ver OBD0 to OBD1) Everything wired ,, engine runs great but no Vtec and somethime the eng light comes on .. Any suggestions......??????
Old May 1, 2005 | 05:40 AM
D-tuned's Avatar
Default Re: Test for Vtec (txq45)
if the check engine light comes on sometimes it sound like you have a loose wire. to test the vtec soleniod, disconnect the connector at the vtec soleniod. run a piece of wire from the vtec soleniod itself(not the green/yellow wire) to the positive side of the battery. as soon as you touch the battery you should hear the soleniod click. if it doesnt click then its bad
b20ricepower
Jul 12, 2025 08:46 AM
swizz977
10
May 25, 2011 08:15 PM
blacktibby07
14
Feb 8, 2011 08:48 PM
AnAccordIsForever
Jun 3, 2008 03:27 PM
the_rail
May 1, 2004 04:44 PM
