Test pipe fitment question help!!!!
Old Jul 27, 2004 | 10:43 AM
Phatch99's Avatar
Default Test pipe fitment question help!!!!
Does a regular test pipe bolts up directly onto a cat back exhaust system or do you have to cut and weld flanges and pipe to make it fit? reason being i have a ek hatch and just got a megan racing cat back exhaust but i have no cat and in need a something cheap like a test pipe from kteller or something but wasn't sure if the normal size length test pipes are made to bolt on directly in place of a cat?
Old Jul 27, 2004 | 12:26 PM
pgpunkguy's Avatar
Default Re: Test pipe fitment question help!!!! (Phatch99)
test pipes are pretty cheap...
a 2 or 3' straight pipe will cost like $10 at a muffler shop
and you can search around for flanges... usually $10 each
use a grinder to cut the pipe to length and
have the muffler shop weld it together for you (~$5)
or have a friend do it for you (free)
if you're gonna have to worry about inspection and/or
emissions testing, i'd recommend getting a carsound cat (~$50)
and have the flanges welded to that...
Old Jul 27, 2004 | 12:31 PM
Phatch99's Avatar
Default Re: Test pipe fitment question help!!!! (pgpunkguy)
i was trying to avoid doing all that cutting and welding at a muffler shop cause most of the muffler shops here won't do it if you r eliminating a cat.
Old Jul 27, 2004 | 01:38 PM
RyanEJ8's Avatar
Do the cutting and measuring yourself then just take it to and exhaust shop and have flanges welded on. Don't tell them what you're using it for. That's what I did.
Old Jul 27, 2004 | 07:03 PM
pgpunkguy's Avatar
Default Re: Test pipe fitment question help!!!! (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Do the cutting and measuring yourself then just take it to and exhaust shop and have flanges welded on. Don't tell them what you're using it for. That's what I did.</TD></TR></TABLE>
or just say it's for when you go to the track...
28
Feb 7, 2011 04:54 PM
93FlatBlackHatch
Mar 3, 2007 01:18 AM
Knightmare69
18
Sep 7, 2004 02:05 PM
Phatch99
Jul 27, 2004 11:39 AM
JDM_Type-R
Jan 2, 2002 04:07 PM
