Tell me whats wrong, PLEASE
Old Jul 16, 2004 | 05:40 AM
VtecSpool's Avatar
Default Tell me whats wrong, PLEASE
So I was driving, the engine started to make this nose like a ticking sound..The harder I rev, the harder and louder the noise got...I pulled into a gas station and found out there was no oil in the motor (wierd because I has an oil change done not too long ago) I put oil into the motor...Turned the car on, let it idle for a while...What happened? The frakin noise was still there...I took my chances and started driving home from work. I was driving and the next thing you know is I hear a loud "Click" in the motor and the car shut off
I tried starting it and nothing.....anyone got an idea what happened?
blown motor, spun rod bearing etc??? HELP!
Timing was off if that helps...
Old Jul 16, 2004 | 06:02 AM
civicminded92's Avatar
Default Re: Tell me whats wrong, PLEASE (VtecSpool)
If it was starved of oil you probably have a spun rod bearing, amid possible other damage. Did the wheels lock up when the motor shut off? If it did, it's probably seized due to the lack of oil and damage incurred from running it in that condition.
Old Jul 16, 2004 | 06:15 AM
VtecSpool's Avatar
Default Re: Tell me whats wrong, PLEASE (civicminded92)
wheels didnt lock, just the motor locked up...tried starting it, no crank...i forgot to mention that it is a mazda mx6 v6...
Old Jul 16, 2004 | 06:19 AM
Automatic or manual?
Old Jul 16, 2004 | 06:29 AM
VtecSpool's Avatar
auto
Old Jul 16, 2004 | 06:34 AM
OK, so will the engine turn over at all? If not, sounds like you have seized something in there, most likely the crank. It may can be reworked, but I'd start searching for a replacement engine as it will likely be cheaper (if you can do it yourself and avoid labor charges).
Sorry man...
Old Jul 16, 2004 | 06:45 AM
VtecSpool's Avatar
yea bro, I already started looking into the KLZE which is the 200hp jdm motor that was found in the mx6....thanx for everything
lilpastrana
Apr 7, 2007 05:25 PM
Hella_Fresh
10
Apr 6, 2007 07:37 PM
dsav4shawn
Oct 7, 2006 03:46 PM
Electron_Blue_Kid
Aug 27, 2006 02:18 PM
screwballz
Dec 28, 2004 02:28 PM
