TDC issues?
Old Jan 27, 2007 | 11:40 AM
The Destroyer's Avatar
Default TDC issues?
Iv been having trouble while getting the TB on once everything is set to tdc. It seems as soon as I put tension on the belt the crank will turn a few degrees. I finally have it close and still am iffy about it. Any siggestions to keep the crank from moving once I apply tension?
Its hard to get an accurate picture of the oil pump marks.
Old Jan 27, 2007 | 12:28 PM
91SiZ6's Avatar
Aren't you supposed to rotate the crank a few degrees to put tension on the belt and then torque the tensioner down?
Old Jan 27, 2007 | 02:03 PM
Default Re: (91SiZ6)
If I do that the bottom end turns while the top remains still as it created tension on the exh side.
I have it all tightened up again, but it is still a hair off. The engine has a 2 layer hg can that be what is causing it?
Old Jan 27, 2007 | 07:28 PM
Muckman's Avatar
Moderator in Chief
Default Re: (DC2 Eric)
Theres def a trick to doing tbelts. I usually back the crank off a bit so when you pull on the belt to put it on the exhaust gear it ends up tdc instead of moving past tdc. Theres also going to be a bit of slack in the belt between the exhaust gear and the crank that will misalign them when you first rotate it, which is also why I recommend backing off the crank so its a few degrees before TDC.
Old Jan 27, 2007 | 07:42 PM
Default Re: (Muckman)
Well im not new to doing timing belts, and iv tried the above method. It just clicks back into place what seems to be a hair past the mark on the oil pump.
Old Jan 27, 2007 | 08:08 PM
Some updated pics, I think this is as good as im going to get it.
Old Jan 27, 2007 | 09:05 PM
Muckman's Avatar
Moderator in Chief
Yeah thats right on the money. Your thinner head gasket is probably throwing it off that little bit. That tiny bit isnt a tbelt tooth, its too little.
Old Jan 27, 2007 | 09:35 PM
Randysi
12
Oct 20, 2011 03:00 AM
ABCVTEC
Nov 19, 2010 02:20 PM
The Destroyer
Jan 29, 2007 05:25 PM
Ryan C
Mar 25, 2004 06:30 AM
Jonathan_ED3
Apr 12, 2003 02:55 PM
