taking off my b16 head help
Old Dec 23, 2004 | 07:44 AM
eg6T's Avatar
Default taking off my b16 head help
to remove the head,what else do i have to remove(internal),are the head bolts under the cams...where are the head bolts?thanks
Old Dec 23, 2004 | 08:09 AM
ohboy95c's Avatar
Default Re: taking off my b16 head help (eg6T)
under the cams. you should be able to see 10 bolt heads that are 12pt. 13mm maybe. remove these and presto. remember the dowel pins may make it a little hard.
Modified by ohboy95c at 10:20 AM 12/23/2004
Old Dec 23, 2004 | 08:18 AM
ohboy95c's Avatar
Default Re: taking off my b16 head help (ohboy95c)
crack head moment, remove the caps and cams and youll see them.
Modified by ohboy95c at 10:21 AM 12/23/2004
Old Dec 23, 2004 | 08:36 AM
eg6T's Avatar
cool man thanks alot
Old Dec 23, 2004 | 01:34 PM
Evs-One's Avatar
Solbros Owns Me
you'll need to remove the cam caps and cams, yes.
And use a 6 pt 14 to remove the head bolts.
Old Dec 23, 2004 | 06:27 PM
eg6T's Avatar
Default Re: taking off my b16 head help (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">you'll need to remove the cam caps and cams, yes.
And use a 6 pt 14 to remove the head bolts.</TD></TR></TABLE>
thanks man
Old Dec 24, 2004 | 09:49 AM
ohboy95c's Avatar
my bad again i'm use to arp's and they are 12 pt
94eh2
Nov 23, 2007 01:53 PM
LSEGHATCH
Nov 15, 2006 12:13 PM
Firestarter
Nov 5, 2005 01:30 PM
zman
Sep 20, 2004 06:01 PM
B_CRUZ!
Jan 10, 2002 10:49 PM
