T belt/tensioner question
Old Apr 9, 2013 | 05:27 PM
jdmh22eg2's Avatar
Default T belt/tensioner question
Ok i have an issue i have not came across before today. I put a new belt and tensioner/spring.
Put all together and used flat screw driver and put tad bit of extra tension on spring (how always done in past), tighten down. Car has a small whine while driving. Ok so belt is to tight. Loose bolt on tensioner and just let it loosen up a bit, and retighten, now has lots of slop.
So then i loosen again add a bit of more tension (less than first time), retighten again but now seems to have small bit of whine still. Not as bad as first go round, but dont like to hear any.
Should i keep F'ing with it or leave small bit of whine to it or leave the slop in it.
Old Apr 9, 2013 | 05:40 PM
grumblemarc's Avatar
The Grumpiest
Default Re: T belt/tensioner question
How much deflection in the belt?
Old Apr 9, 2013 | 05:44 PM
jdmh22eg2's Avatar
Well in back side (wp side) i would say roughly 1/8" (only guessing off top of head from what i remember), it pushes in but not a lot(that is at its loosest while going thru full timing cycle by hand turing. Front of belt has about same as back maybe tad less
Old Apr 9, 2013 | 05:47 PM
The Grumpiest
I would check it against the FSM.
Old Apr 9, 2013 | 05:48 PM
jdmh22eg2's Avatar
Ok just went and checked again maybe 3/16" of deflection and 45deg of twist to it
Ok will look it up on SOMEDATA tmrw at work
3s1k
Sep 27, 2010 01:58 PM
Ge-money
Mar 24, 2010 06:35 AM
importrule
Mar 2, 2007 08:59 AM
SHG_EasyE
14
Dec 18, 2006 05:50 AM
TodaSi
Jul 16, 2002 03:06 PM
