swap problem
Old May 16, 2011 | 11:22 PM
spawnkid's Avatar
Default swap problem
K so here is the deal. I have a 97 coupe. I put a b16 in it and long story short I had to take it out. I now have a d16y8 in it. I haven't finished the install because I'm getting different info from a couple people. First off the guys that installed the b16 used my wire harness from my stock motor. Now the mechanic that is helping me said the wire harness won't work for the d16y8. Well he said it will work but we have to do a little rewireing. Second he said I am missing my clutch slave and clutch fork. From what I know that stuff is in the tyranny but I'm not 100%. Can somebody give me some suggestions as to what i would need to do to make this swap work? Will I need to just find a wire harness for the motor or can I use the one I have? I'm so lost with this and would really appreciate some input please.
Old May 17, 2011 | 12:25 AM
spawnkid's Avatar
Default Re: swap problem
Bump.....please I really need some help on this swap asap.
Old May 17, 2011 | 06:41 AM
spawnkid's Avatar
Bump.....
Old May 17, 2011 | 12:52 PM
mouab18c1's Avatar
You b16 harness should work as long as they are both the same obd. Your slave cylinder is mounted on the front side of the transmission. Note you cannot use the b16 tranny on a d series. Your fork is on the inner part of the tranny. If it is there you should be able to see it since it hooks up to the slave cylinder.
Old May 17, 2011 | 08:52 PM
spawnkid's Avatar
Ok that helps a lot. I have the D series tranny in so that's not a problem. If at all possible could someone take a pic or something of what I'm looking for? I tried searching but came up with nothing.
Thank you.
Old May 17, 2011 | 09:27 PM
mouab18c1's Avatar
What exactly do you want a picture of?
Old May 17, 2011 | 09:41 PM
spawnkid's Avatar
What it all looks like installed. It's been so long since anything has been in this car that I can't remember how that area looks with a single cam.
Old May 17, 2011 | 10:57 PM
mouab18c1's Avatar
google it. On the left click the images tab
b16bri
Aug 19, 2015 04:04 AM
418whpturboD
Nov 19, 2008 09:04 AM
stemiched
Aug 8, 2006 09:45 PM
Hazymix
Jul 16, 2006 12:44 PM
h22blazerz5
Dec 31, 2005 07:53 PM
