suspension problem?
Old Nov 28, 2003 | 11:43 AM
Powered by Honda's Avatar
Default suspension problem?
After a gsr front brake swap, I noticed that outside of the negative camber, my 2 front wheels are also pointing slightly inward, is this an issue that a simple alignment can resolve or should I be concerned about something else? Just wondering because I've never seen this before and it looks a bit peculiar. Thanks for any help...
Old Nov 28, 2003 | 02:40 PM
tegra_gsr's Avatar
Default Re: suspension problem? (SoichiroH)
yes.. that is definatly a problem with the toe of your car.. all u need is to get ur alignment done.. did u take apart just the brake assembly?? or did u take off anything else..??? when u go to ur alignment FOR BEST RESULTS.. all four tires need to be fairly new, possibly under a week... or atleast evenly worn...
Old Nov 29, 2003 | 01:26 PM
Default Re: suspension problem? (tegra_gsr)
Alright, thanks for the info. The entire front knuckles were swapped out on my EK in favor of GSR ones in order to utilize the brakes. So it wasn;t just the brake assembly itself that was worked on...
Old Nov 30, 2003 | 05:54 PM
tegra_gsr's Avatar
yep... just take it to an alignment shop.. they'll fix it all for u...
Nighthawk R18
Honda Civic (2006 - 2015)
12
Sep 4, 2007 08:34 PM
hugegastros
Suspension & Brakes
May 23, 2006 07:45 AM
daveb91
10
Dec 8, 2005 11:52 AM
latrungkiet
Jul 5, 2005 03:33 PM
Powered by Honda
Nov 28, 2003 06:17 PM
