Suspension install, how do I get this bolt out?
Old Sep 20, 2003 | 05:09 PM
psdvette's Avatar
Default Suspension install, how do I get this bolt out?
How do I get that bolt off? the bolt in the center of the screen. It is the rear shock cap bolt. I used a allen key and a wrench and held the allen to the ground, and proceeded to strip out the allen part. both fronts came off fine which makes me even more worried. I already searched and came up with nothing. Any help is apperciated, thanks.
Old Sep 20, 2003 | 05:13 PM
mmuller's Avatar
Mad Scientist
Default Re: Suspension install, how do I get this bolt out? (psdvette)
impact it out
Old Sep 20, 2003 | 05:26 PM
psdvette's Avatar
Any easier way? If I have to I'll go impact it out tonight, just I don't have one right with me... thanks for the reply any other suggestions?
Modified by psdvette at 2:36 AM 9/21/2003
Old Sep 20, 2003 | 05:27 PM
GSRrR's Avatar
Default Re: (psdvette)
if its stripped, then impact is the only way....
are you gettin new shocks? you can use a clamp to hold the shaft of the old shock to keep it from turning. it will damage it tho...
Old Sep 20, 2003 | 05:28 PM
Double121's Avatar
Impact gun and stand away from the spring and shock cause its under a load.
Old Sep 20, 2003 | 05:37 PM
psdvette's Avatar
I have spring compressors... when i turn it without the allen it just spins, the impact gun will take it off for sure? Thanks for all the help.
Old Sep 20, 2003 | 06:08 PM
hayabusa160's Avatar
if that dont work use a torch i had to do that with my friends ended up distroying the nut just to get it off same **** the rear suspesnsion always a bitch.
Old Sep 20, 2003 | 07:44 PM
psdvette's Avatar
Hey just tried the impact wrench, didn't even come off with the impact wrench. I'm about as frustrated as possible right now. Can I just hacksaw off this b**ch?
Old Sep 20, 2003 | 08:50 PM
jansenrw's Avatar
try heating it does wonders.. if not use a breaker bar!!!!, all else fails yeah cut it off!!!!
Old Sep 20, 2003 | 09:13 PM
TimoneX's Avatar
New User
Default Re: (jansenrw)
Locking vice grips tightly on the damper shaft between the coils will help discourage the shaft from rotating with the nut on top of the mount. Be careful if you get it really hot and then put the impact to it, they occasionally pop apart and will give you a nice gas shower.
Old Sep 20, 2003 | 09:20 PM
bartek_b's Avatar
Default Re: (GSRrR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRrR &raquo;</TD></TR><TR><TD CLASS="quote">are you gettin new shocks? you can use a clamp to hold the shaft of the old shock to keep it from turning. it will damage it tho...</TD></TR></TABLE>
very hard to do on a smooth surface
Old Sep 21, 2003 | 12:53 AM
GSRrR's Avatar
Default Re: (mugen85r)
opss sorry meant a vise grip....
use the impact with the vise grip. we had to do this to my friends shocks...you have to be careful with those allen wrenches, it has to fit tightly for it not to strip.
.colin
Northeast
Apr 13, 2008 09:59 AM
Vtakkk
Suspension & Brakes
Aug 3, 2006 02:52 AM
thw_goalie
Suspension & Brakes
Mar 29, 2006 11:08 AM
chris215chris
Aug 17, 2003 08:18 PM
95excoupe
Jan 27, 2002 10:12 AM
