Surging Idle? How-To Tech Article...(56k beware)
Old May 26, 2008 | 06:13 PM
  #151
Bad_dude's Avatar
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Since you may have introduced air into the coolant system, make sure to re-bleed the coolant once everything is back together. Air bubbles in the coolant can trick the ECT sensor which will cause a surging idle.</TD></TR></TABLE>
How can I bleed the coolant without changing the fluid? I have a 1990 Accord LX, 4 door.
Thanks.
Old May 26, 2008 | 06:42 PM
  #152
Bad_dude's Avatar
Default Re: surging idle not fixed/solutions. (chemicalanarchy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chemicalanarchy1 &raquo;</TD></TR><TR><TD CLASS="quote">NOw I'm sure that some of you are thinking that I should 'bleed the coolant system' and I'll just say that's a joke cause if you EVER pull off one of those hoses going to the IACV or FITV when the car is warm and running and you see the volume going through those hoses you will realize such a suggestion is a joke and the only AIR BUBBLES one is going to get stuck with that much volume is via cavitation................so don't waste your time on THAT!
Hi,
Are you saying that bleeding your coolant is not necessary after this procedure?
Thanks.
Modified by Bad_dude at 8:42 PM 5/26/2008
Old May 27, 2008 | 08:10 AM
  #153
Bad_dude's Avatar
Default Re: surging idle not fixed/solutions. (Bad_dude)
I can't find the radiator funnel in any of my nearby auto part stores. I have tried Autozone and Kragen. So far driving it without bleeding, the car seems fine. Coolant warm up and fan on periodically. The system seems fine. I have not yet to drive on the freeway. I'll do that when I go to work later on. Let's just hope it does not cause overheating with small air bubbles. I am going to have my coolant change this Friday any way, which is 4 days away.
One problem I have noticed today was when I start the engine totally cold this morning, my idle was only around 1000rpm instead 1500rpm as before. However, the car warms up fine and idle went down to around 600rpm steady. Driving, braking fast, stopping, or shifting, the idle is steady. I am going to change out the hose clamps on the FITV later stop the small leaks.
Thanks.
Old May 29, 2008 | 09:50 PM
  #154
sevendurt's Avatar
hey i think this is the prob im having but i have a blox 70mm tb with no inlets for the coolant hoses so i just have a screw for my fitv i have funny idle at 2k i will bog back to 1k then back up again dont know what to do.
Old Jul 15, 2008 | 02:52 PM
  #155
92integra-R's Avatar
Default Re: Surging Idle? How-To Tech Article...(56k beware) (honda_power69)
fixed my idle!! it was the white screw thing inside the FITV. thanks!!
Old Oct 23, 2008 | 06:07 PM
  #156
fratt3's Avatar
New User
i have the same problem as everyone else pretty much.i have a 99 em1, i have had a cel on for like almost a year for the IACV, i just replaced it and still getting the same cel, i cleaned out the PCV, adjusted the idle adjustment screw, the only thing i havent tried was checking the FITV, but my car doesnt have the FITV on the bottem of the TB like most civics have. there is a coolant line that runs from, the main coolant line to the block, to the TB then the outlet side goes to the IACV. there is nothing to remove tho, the nipples for the coolant lines are all one piece with the TB. Do i just not have a FITV or is it located else where?
Also when i took my intake off and opened the throttle body it looks as if there is oil or somethin black and wet on the inside of the intake manifold.
anything would help, need to fix ASAP to pass Inspection.
Old Oct 25, 2008 | 12:14 PM
  #157
vti444's Avatar
had issue on my 97 ek4 (b16a2 0b2a) for about 2 years now and gotten worse, really fed up with it
gonna go through as many steps as poss in this thread over next several days
i assume from what ive read here that my car wont have the fitv or its located somewhere else ?
Old Nov 7, 2008 | 12:49 PM
  #158
vti444's Avatar
Default Re: (vti444)
ok, looked into this and i dont have fitv so guess i need to dig deeper now, im guessing iacv or power fc is causing my problem so time for me to read up
Modified by vti444 at 8:20 AM 11/8/2008
Old Dec 11, 2008 | 07:37 PM
  #159
darwin1859's Avatar
Hi Honda Power - I can't see the pics. could you check the links? Thanks!
Old Apr 9, 2009 | 06:31 AM
  #160
atgrubb23's Avatar
Hi guys, posting on my brother's account because I don't have time to swap over right now. The images in the original post have been missing for at least a year due to the picture hosting site closing. I just found all the original photos from this write-up on my old hard drive the other day, so I'll rehost them elsewhere and get em back up before the weekend hopefully.
Glad this thread is still helping people at least
Old Apr 9, 2009 | 02:42 PM
  #161
GQej1's Avatar
damn it the pictures don't work.
Old Apr 22, 2009 | 07:10 PM
  #162
Civicbeater's Avatar
bump for rehosting pics!
Old Apr 25, 2009 | 12:16 PM
  #163
GQej1's Avatar
YAY... I just fixed it. THANK YOU FOR THIS WALK THROUGH...didn't even need the pictures :-)
Old May 12, 2009 | 06:49 PM
  #164
99d-series's Avatar
cant see the pics and i need help
Old May 21, 2009 | 09:15 AM
  #165
d1n0's Avatar
i cant see the pictures too
help
Old Jun 3, 2009 | 05:03 AM
  #166
Hulkdon1's Avatar
This is a pefect example of how helpful this site is. I just did this procedure to my FITV and the surging stopped. The info is greatly appreciated. Nice job on the step by step write up.
Old Jun 30, 2009 | 09:36 AM
  #167
djnikko's Avatar
My idle seems to surge when the car is warm not when cold. Can anyone give me an indication to what this could mean? Ive cleaned the FITV and EACV
Thanks in advance
Old Jul 1, 2009 | 10:49 AM
  #168
EG6 Love's Avatar
i did this on my 92 si, and in the winter when its 20 degrees or below my car will idle fine but if the throttle is touched before the car is warm the rpm's will drop really fast and sometimes stall the car.
just beware. did fix my slight surge and made my idle smoother.
Old Jul 1, 2009 | 02:12 PM
  #169
djnikko's Avatar
Heres a vid of my idle surge...
http://www.youtube.com/watch?v=ALzVy9T2_4M
By the way thats me shutting the engine off at the end, its not stalling or anything.
Old Sep 23, 2009 | 01:17 PM
  #170
tek888's Avatar
Sweet write up. Can't believe how loose my fitv was. Thanks a lot!
Old Sep 23, 2009 | 02:36 PM
  #171
joemonster's Avatar
Wow.. I cant wait to get into my bay tomorrow and see if I can fix my surge Lmaoo!! ty!!
My idle only surging when its cold, just like this threat says, and its nothing too bizarre but annoying!!
Thankyou!!
Wish there was pictures, but I'm sure I can manage w/out, ty ty =D
Old Sep 24, 2009 | 11:04 AM
  #172
catbass's Avatar
New User
please post pics..thanks
Old Dec 29, 2009 | 02:39 PM
  #173
standal1complex's Avatar
didnt need the pics and now my hunk o junk runs awesome!! the two little screw bolts on the plate just snapped right off lol JBweld is awesome. this fix even cured my stupid idle sputter. thank god for honda tech :-) thanks for the super helpful write up
+111111
Old Jan 8, 2010 | 01:37 AM
  #174
ANTI nwp4life's Avatar
New User
bump up! this thread is helpful... i didnt even know that FIT valve even existed! now i can give this advice to another honda owner and look like i known it lol!
thankz honda_power69 you the man.
the idle light weight fluctuates up and down? is it normal if the idle surges under grand?
Old Feb 27, 2010 | 06:30 PM
  #175
H22Barbie's Avatar
New User
I like the idea to clean the fitv but I got something interesting. Mine does the surge from 1-2k non stop little after I start it up. NON STOP. I sprayed around the TB and found one spot that makes the motor pick up like crazy . I changed the tb gasket and it still does it. When I spray the fluid on the specific side of the TB you can seee and hear it suck the fluid in on top of hearing the motor speed up. Would it be a good idea to RTV the spot that leaks? I know a bunch of race teams that rtv their intakes. Seems cheap but sometimes the moment calls. Just wanna see if anyone else has done this...
