surging idle = vac leak?
Old Mar 16, 2003 | 09:36 PM
avex's Avatar
Default surging idle = vac leak?
my car's idle has been pretty messed up lately, it goes from 800 to 1000 and back. Also, I noticed that my boost gauge (which normally reads 17 vac at idle) goes from 17 to 15 and repeats. Do I have a vac leak?
Old Mar 17, 2003 | 06:23 AM
1hottEG6's Avatar
Default Re: surging idle = vac leak? (avex)
COuld be a few things man,
Check all ur hoses *cracks., loose...etc
Then check ur TB gasket * rips
Then Could be ur IACV *located back of Inatke manifold
Or coul dbe ur coolant bypass, take ur TB off, and there are 2 coolant lines running through it. Take that peice apart and there is a white screw in there. Sometimes that plastic screw comes undone, and cause ur car to idle funny..
Good luck
Old Mar 18, 2003 | 08:05 AM
b18cvtec's Avatar
that just happened to me on my 94' gsr. i found a small head gasket leak and decided to take the head off machined it so it was completely flat. replaced with a mugen head gasket and no more problems with a little more compression.
Old Mar 18, 2003 | 05:44 PM
riceboy's Avatar
Default Re: surging idle = vac leak? (1hottEG6)
Good luck
try all that to a good reply
crazyboy
Dec 29, 2012 06:46 AM
HotCheetos
Dec 23, 2010 01:41 PM
hammergunner
Dec 9, 2009 10:13 AM
twentyhurtz
Jan 16, 2009 08:30 AM
go2sleep
Jun 27, 2006 01:36 PM
