another high idle problem
Old Jun 26, 2006 | 11:53 AM
go2sleep's Avatar
Default another high idle problem
my idle stays roughly at 1200-1500 rpm. i changed out the FITV with a newer one.
i noticed when i spray carb cleaner directly at the throttle body (where the throttle cable spring is) the car seems to either choke or rev higher. could the gasket/throttle possibly be the cause of the high idle?
Old Jun 26, 2006 | 12:04 PM
nObOdy65's Avatar
Default Re: another high idle problem (go2sleep)
My gasket was what was causing my high idle, check that, check for a vacuum leak, check your iacv and please please search next time.
Old Jun 26, 2006 | 02:13 PM
DC2 Mang's Avatar
check to make sure yout iacv is tight and the TB gasket
I would take the IACV off and blast it would with some gun scrubber (you can get it at wal-mart) or some carb cleaner and inspect it for cracks
check over your vacuum lines and make sure there are no holes in them
Old Jun 27, 2006 | 01:36 PM
go2sleep's Avatar
problem fixed. changed out the throttle body gasket (felpro # 60973) and put in a newer IACV. idle now is 750rpm.
could have just been the gasket or just the IACV. but i know for sure, i had a leak where the tb sat next to the manifold.
thanks to all with positive outlook.
Excusetoboost
Sep 1, 2011 07:40 PM
h-o-n-d-a
Aug 3, 2009 05:15 PM
the_dxB16
Mar 13, 2008 10:47 PM
95dc2teg
Sep 11, 2007 05:49 PM
metal-x
Nov 21, 2002 05:35 AM
