Jumping Idle
Jumping Idle
my idle in my 94 del sol keeps jumping for 1000 to 3000
its a b16a motor, and i've replaced the IACV what else effects the idle
Re: Jumping Idle
there is no fast idle Value on this manifold
could it be any other sensors that are making it ldle wired
i also replaced the Head gasket,manifold gasket and the throttle body gasket
so i know im not leaking any vacuum
Re: Jumping Idle
Take brake cleaner spray it on your gaskets and hoses anywhere it could have a leak.If its leaking when you spray it on there it should idle fine
Re: Jumping Idle
Ive seen felpro manifold gaskets fail after doing head gaskets so after the first couple i seen with vacuum leaks i started using honda intake manifold gaskets only, torqued to spec btw . Spray carb clean on the gasket (between the manifold and head...) and also on the tb if you come up with nothing take it all apart and have a look maybe you made a mistake on the install. Nobody is perfect....
Live and learn
Let me know the outcome of what ya found
Live and learn
apbtwhiskey
04-05-2013 01:51 PM
saikouEF8
06-15-2006 04:31 AM
