stumped - help me out...
Old Jul 14, 2004 | 08:02 PM
navin's Avatar
Default stumped - help me out...
Ok I have been having some idle problems with my car, not a flucuating idle up and down..
But rather it wll stay around 1k, and then when u come to a stop it will drop down to almost dead and stay around there or try to bounce back up... The car NEVER dies, but its annoying..
I have changed - fuel pump, fuel filter, cleaned IACV, throttle body...
It almost seems as if the car isnt getting something, something I have no clue what it is...
motor is
b18c1
.25 over JDM ITR slugs [11.4:1] ish compression
stock airbox
jdm 4-1
2.5" mandrel bent piping..
Now some things that I have tossed over in my mind that might help solve the problem..
- new injectors?
- leak from gasket - my guess IM [had a hard time torqueing it]
- throttle body [ friend fug with the linkage, thinking it adjusted idle ]
thanks
Old Jul 14, 2004 | 08:06 PM
ef9wpb's Avatar
Default Re: stumped - help me out... (navin)
do u have a lightened flywheel?
Old Jul 14, 2004 | 08:39 PM
eda6's Avatar
Check tps and map sensors.
Have you done a tune up lately?
Old Jul 15, 2004 | 05:14 AM
navin's Avatar
Default Re: stumped - help me out... (eda6 hb)
yes, i have a lighter flywheel. I had it before and it idled perfectly...
tuned up, when i redropped the motor in new plugs, wires...
Old Jul 15, 2004 | 05:44 AM
deSigi's Avatar
Has your idle been like this since you changed pistons? If so, check your timing, might be a bit off. That's what happened to me.
Old Jul 15, 2004 | 06:05 AM
navin's Avatar
Default Re: (deSigi)
yeah it has, any idea what my timing should be set at...
I took it to a shop because I didnt have a gun, and just wanted it finished. Right now it looks FULL advanced...
Old Jul 15, 2004 | 07:18 AM
deSigi's Avatar
With high compression I was told that it would be necessary to retard the timing a bit. Stock it's at 16 BTDC, so you might need to set it at 14 or so. You'd need a shop to tune it properly though.
Old Jul 15, 2004 | 08:18 AM
navin's Avatar
ya sure?
Old Jul 15, 2004 | 09:31 AM
deSigi's Avatar
Default Re: (navin)
That's what I was told. I'm not well informed about comperession vs. timing, but that's a couple of shops have told me.
Old Jul 18, 2004 | 08:05 PM
navin's Avatar
ok... NOW
the car just dies on coldstart, and when warmed up... It wont hold an idle..
I can drive it, full warmed up. Come to a redlight and when i stop and put the revs fall down, it will just stall out. Sometimes it wont, but its pretty close.
Could this be an ignitor/cap/dizzy problem, or maybe my timing is off by a tooth??
Old Jul 18, 2004 | 08:13 PM
eda6's Avatar
Default Re: (navin)
Is the im gasket sealed?
Sounds like the problem to me.
Old Jul 18, 2004 | 09:54 PM
boostn420's Avatar
Default Re: (eda6 hb)
If it was a bad intake manifold gasket the idle would be way to high and it would never stall.
Old Jul 20, 2004 | 03:43 AM
Drew M's Avatar
New User
Default Re: (boostn420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">If it was a bad intake manifold gasket the idle would be way to high and it would never stall.</TD></TR></TABLE>
Exactly.
Cleaning the IACV doesn't fix it if it is bad. I have never had one go bad on any of my Hondas BUT I have seen them go bad on my Fords and they do what you are describing.
I would also check your battery/alternator. At idle, when the alternator is running the slowest the system relys on the battery since everything the alternator is putting out goes to run the ignition and ECM. If either of those are weak or failing they can cause problems like what you have described.
Old Jul 20, 2004 | 05:10 AM
navin's Avatar
Default Re: (Evil Drew M)
Cool thanks..
I think I better replace the IACV, and check timing...
f22vtec1
16
Mar 4, 2011 09:07 PM
rcjustin
26
Feb 3, 2006 10:37 AM
Cburt24
Feb 20, 2004 02:38 PM
Accord15
Oct 22, 2002 01:34 PM
Fatty_1775
Aug 11, 2002 07:28 AM
