STUD removal.....how ?
Old Jul 10, 2003 | 01:20 PM
Beave0101's Avatar
Default STUD removal.....how ?
The studs on the intake manifold, that connect thr throttle body, (and the ones for the fuel rail, which are much smaller)
How do you remove these? And properly torqe them down? Just when i think i have all the tools......
Old Jul 10, 2003 | 02:32 PM
wanttorace's Avatar
Default Re: STUD removal.....how ? (Beave0101)
i put vice grips on the part where there are not threads and turn with your life
Old Jul 10, 2003 | 03:23 PM
976's Avatar
976
New User
Default Re: STUD removal.....how ? (jjd493925)
No more than 13lbs of torque!
Old Jul 10, 2003 | 04:45 PM
Beave0101's Avatar
i tried that but I'm not too comfortable doing it, slight pressure already scratches it.
And isnt there an actual tool when you need to torque them down ?
Old Jul 10, 2003 | 05:15 PM
MaxSterling's Avatar
if the studs are not snapped in half, then its ez to remove and install.
here is what you do, get two nuts that will thread into the stud... screw one in and then screw the other. hold one nut and tighten the other so that both nuts are jamming each other....
to remove turn the inside nut, to install turn the out side nut....
get the picture? too bad if you don't....
Old Jul 10, 2003 | 07:06 PM
mr.beeks's Avatar
Default Re: STUD removal.....how ? (RoyFokker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyFokker &raquo;</TD></TR><TR><TD CLASS="quote">if the studs are not snapped in half, then its ez to remove and install.
get the picture? too bad if you don't....</TD></TR></TABLE>
best advise dont use the vise grip method......
Old Jul 10, 2003 | 07:08 PM
Bananabrya's Avatar
go to google. Type in "double nut stud method". Click a link.
Old Jul 10, 2003 | 07:36 PM
Beave0101's Avatar
thanks guys, and to (bseries) for im'ing me.
what to do if I need to actually torque these down though ?
-a
Old Jul 10, 2003 | 08:06 PM
b19coupe's Avatar
Same thing. Double nut, and use the nut to torque the stud.
1slwEK
Feb 3, 2008 06:16 AM
pinecone
May 29, 2007 12:30 PM
AdReNaLiN
Apr 2, 2006 01:57 AM
93si-hybrid
Jun 18, 2005 04:23 PM
david90
Jun 8, 2004 02:47 PM
