Stripped head bolt threads
Old Feb 16, 2004 | 09:51 AM
DonF's Avatar
Default Stripped head bolt threads
We have just recieved our prototype block repair kit that repairs stripped head bolt threads in the block. It works . It installs a 30mm threaded steel sleeve at the correct location. We know offer the repair for $40.00 for the first hole and $10.00 each after that. The kit with Block plate, drill bushing, center finder, two-step drill, tap, and installer, etc. should be avail. in a month or so if you are interested.
Old Feb 16, 2004 | 09:53 AM
fearless_dsm's Avatar
Default Re: Stripped head bolt threads (DonF)
im very interested...
Old Feb 16, 2004 | 10:01 AM
LudeyKrus's Avatar
Sounds like a good price, but those are just Helicoils from any good auto store.
aka CaseSavers
Old Feb 16, 2004 | 10:14 AM
Default Re: (LudeyKrus)
weve tried using regular helicoils and the thread pattern on them dont match the head bolts exactly...
Old Feb 16, 2004 | 10:20 AM
LudeyKrus's Avatar
Default Re: (fearless_dsm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fearless_dsm &raquo;</TD></TR><TR><TD CLASS="quote">weve tried using regular helicoils and the thread pattern on them dont match the head bolts exactly...</TD></TR></TABLE>
Are you sure? B/C they give you a drill bit to drill out the old hole, and you rethread the hole w/ a tap they give you then you insert the "coil" which is what holds the bolt.
Old Feb 16, 2004 | 10:23 AM
yea..i know all that..the coil is basically the new threads on the block..but those threads dont match up to the threads on the head bolt...they're a little bit finer...
Old Feb 16, 2004 | 11:29 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fearless_dsm &raquo;</TD></TR><TR><TD CLASS="quote">yea..i know all that..the coil is basically the new threads on the block..but those threads dont match up to the threads on the head bolt...they're a little bit finer...</TD></TR></TABLE>
you can get helicoil with stock size threat and pitch
Old Feb 16, 2004 | 03:41 PM
MadtownSi's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
you can get helicoil with stock size threat and pitch</TD></TR></TABLE>
I'm sure you can.
Old Feb 16, 2004 | 07:07 PM
S.P. BUILT's Avatar
is this kit "time-serts"?....sounds exactly like it!!!
Old Aug 3, 2004 | 01:15 PM
lysergican's Avatar
Default Re: Stripped head bolt threads (S.P. BUILT)
what is the thread / pitch size of the head bolt threads? anybody here know where i can get a kit to repair the head bolt thread?
Old Aug 4, 2004 | 09:07 PM
turbohondask's Avatar
Default Re: Stripped head bolt threads (macroresin)
Time sert is one of the best kits
https://honda-tech.com/zerothread?id=222925
pics dont work anymore
Old Aug 4, 2004 | 10:14 PM
Sack Master's Avatar
Default Re: Stripped head bolt threads (turbohondask)
I perfer keenserts myself over timeserts. But both of them work wonders.
DeeEx Rex
10
Jul 29, 2010 11:02 AM
sonofsam
Nov 7, 2005 08:26 AM
jmcclell
Jun 19, 2005 03:01 PM
1bar
May 12, 2004 10:33 PM
