Strange noise
Old Aug 24, 2005 | 10:19 AM
LSVtechnologytur...'s Avatar
Default Strange noise
Hey guys, the other day when I was getting my car tuned it started making a very strange / bad noise between idle and 2krpm. its very similar to the noise the lude in this video is making but a little louder https://honda-tech.com/zerothread?id=1245732
I have replaced all the lma's, and my compression was 190 190 185 190. I noticed today that it only starts happening after the motor has been running for a few minutes and starts warming up.
Since my compression was good I thought it might be clutch/ transmission related... but it seems to go into gear fine and move without a problem
background info:
ls-v
arias pistons (rings gap .018 & .020)
eagle rods
9.6:1 compression
If anyone can help or just give me a place to start looking it would be greatly appreciated
Old Aug 24, 2005 | 01:54 PM
racer_X_123's Avatar
Default Re: Strange noise (vtec'n)
the video didnt play for me, Um are all the valves within spec from the cam, sheck the valve adjustment if it is a clicking sound
Old Aug 24, 2005 | 10:40 PM
RYANR1's Avatar
Use a stethoscope to locate the noise.
Old Aug 24, 2005 | 11:10 PM
MaxxRedemption's Avatar
Default Re: Strange noise (RYANR1)
my pops car was making that noise, used a stethascope to find it, turned out it was cracks in the heads, lots of em, in both heads
Old Aug 25, 2005 | 10:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RYANR1 &raquo;</TD></TR><TR><TD CLASS="quote">Use a stethoscope to locate the noise.</TD></TR></TABLE>
I tried once and had a hard time pinpointing the noise, i'm going to try agian though.
Old Aug 25, 2005 | 10:30 AM
Default Re: Strange noise (MaxxRedemption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxxRedemption &raquo;</TD></TR><TR><TD CLASS="quote">my pops car was making that noise, used a stethascope to find it, turned out it was cracks in the heads, lots of em, in both heads</TD></TR></TABLE>
Wouldn't I have bad compression if the head was cracked anywhere?
Old Aug 25, 2005 | 10:42 AM
what also works quite well, take a phillips screw driver, stick the point on the head, or where you want to try to pinpoint the noise, then take the part where your hand goes and put that to your ear, it works almost as good as a stethiscope.
Old Sep 6, 2005 | 08:30 PM
type Gendy's Avatar
Default Re: Strange noise (racer_X_123)
figure it out yet?
Old Sep 10, 2005 | 06:24 AM
Default Re: Strange noise (type Gendy)
not yet
Old Sep 11, 2005 | 08:34 PM
is it possible that an ecu problem could cause sporadic noises from a motor?
Old Sep 12, 2005 | 05:40 AM
type Gendy's Avatar
I dont THINK the ecu could cause noises in teh motor ??
Old Sep 17, 2005 | 06:53 AM
Hey everyone, I finally figured it out. It was the vtec solenoid. For some reason (maybe bad wiring) I was getting 12v directly to the solenoid constantly. So after the car warmed up vtec would kick on and off at idle. This not only made a really bad noise but caused the car to run like complete ****. Now that its fixed its a night and day difference in the way it runs.
Old Sep 17, 2005 | 07:12 AM
type Gendy's Avatar
GLAD U FOUND IT, GOOD POST
hmaugans
Honda S2000
14
May 15, 2009 04:56 PM
DTA-Zombie
13
Aug 8, 2008 08:40 AM
Azxster
Sep 28, 2007 08:16 PM
My97lude
Jul 12, 2007 10:32 PM
LSVtechnologytur...
Sep 6, 2005 08:21 PM
