Is the stock fuel pressure between a b16a2 and d16a6 the same?
Old Oct 28, 2002 | 10:35 AM
b16awarrior's Avatar
New User
Default Is the stock fuel pressure between a b16a2 and d16a6 the same?
Because im swapping my frends B&M regulator off of his 2000 civic si and he's going to put my crx Si on his car since he's selling it. (Sorry, didnt realize I had double posted )
[Modified by b16awarrior, 7:38 PM 10/28/2002]
Old Jan 23, 2003 | 09:40 AM
k HATER's Avatar
Default Re: Is the stock fuel pressure between a b16a2 and d16a6 the same? (b16awarrior)
Let us see if this crafty little experiment works....and if it does......I am going to Laugh....Sorry.......No one cares again......or do they?
Old Jan 23, 2003 | 09:58 AM
Shawn C's Avatar
In The Garage
Default Re: Is the stock fuel pressure between a b16a2 and d16a6 the same? (k HATER)
sorry man, youre too new to try to be funny. the fuel pressure may be the same (~43 psi), but the B16A has a bigger fuel pump (~134 lph), and bigger injectors (~270cc), thats how it gets more fuel, so putting on the regulator should be no problem, but make sure you have a fuel pressure gauge to check it
[Modified by 22lbGS-R, 7:00 PM 1/23/2003]
Old Jan 23, 2003 | 10:10 AM
Urban Business
Guest
Posts: n/a
Default Re: Is the stock fuel pressure between a b16a2 and d16a6 the same? (22lbGS-R)
b16s use 240cc jectors. stock d16a6 fp is 38psi
270cc = accord and ludes.
and your too new to give out false info
[Modified by TorteX, 1:11 PM 1/23/2003]
Old Jan 23, 2003 | 10:45 AM
Shawn C's Avatar
In The Garage
Default Re: Is the stock fuel pressure between a b16a2 and d16a6 the same? (TorteX)
so, youre saying that GS-Rs and Sis come with 240cc injectors, not 270cc?
Old Jan 23, 2003 | 01:31 PM
AzG35's Avatar
Yes, this is correct, all B series injectors are 240cc
Old Jan 23, 2003 | 02:54 PM
kyle h.'s Avatar
Default Re: Is the stock fuel pressure between a b16a2 and d16a6 the same? (AzSi22)
maybe i didnt read your post correctly...but the b&m fuel reg. can be adjusted and most honda regulators are similar so the b&m cap style reg will fit and run fine...but u definatly want a fuel pressure gauge.
edit: read ur post again. your wanting to know if it will be ok for his car? yes, they should be the same regulator.
[Modified by kyle h., 11:56 PM 1/23/2003]
Old Jan 23, 2003 | 03:54 PM
Shawn C's Avatar
In The Garage
i guess you learn something new every day. ive always thought B-series injectors were 270s. oh well.
teknics1
May 29, 2006 12:30 PM
Niskyspy
Mar 4, 2006 03:30 PM
aalb1
Nov 2, 2005 10:47 AM
B18EG6
Jun 15, 2004 11:19 AM
