sputtering, backfirign in downpipe?
Old Dec 31, 2006 | 08:14 AM
w0ng_sta's Avatar
Default sputtering, backfirign in downpipe?
Hey guys, i have a b16-T with a 2.5 turbo back, tuned on hondata, @ 8.5psi
Lately when im driving the car seems fine unless i accelerate past 5k.. at WOT, the car will run fine up to around 5k which is usually around 7psi at that time and the car bogs and it sounds like the car is backfiring but the noise seems to be coming from in the engine bay. IT also isnt one loud noise.. but several sequential noises almost like loud sputtering.. other than that the car's overall driveability is fine. i tried to ease the motor above 5k rpm and i did then i opened the throttle up and it happened again only this time at around 6.5k rpm.
I occasionally get a primary o2 code but ive been running without o2 sensors for some time now with no problems. With the o2 code I also sometimes get a tps code.. this i usually just clear while moving by killing the ignition then popping the clutch.. could the tps be the source of this problem?? thanks
Old Jan 2, 2007 | 07:11 PM
roadracer321's Avatar
Default Re: sputtering, backfirign in downpipe? (w0ng_sta)
sounds like possible fuel starvation. Do you have a wideband? What is your fuel pressure? Injector size?
Old Jan 3, 2007 | 07:12 AM
mrmckie's Avatar
sounds like the same crap that is happening to mine, but i'm NA. it doesn't happen all the time just occasionally. I go up to about 3K and it starts sputting rmps drop to about 2.7K them the car takes off back up to 3K and falls back down to 2.7K and repeats depending on how fast i'm going and the rpm range i'm in.
but it doesn't do it all the time just occasionall. so i'm confused as hell
Old Jan 3, 2007 | 05:11 PM
boost'd_crx's Avatar
Default Re: (mrmckie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmckie &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the same crap that is happening to mine, but i'm NA. it doesn't happen all the time just occasionally. I go up to about 3K and it starts sputting rmps drop to about 2.7K them the car takes off back up to 3K and falls back down to 2.7K and repeats depending on how fast i'm going and the rpm range i'm in.
but it doesn't do it all the time just occasionall. so i'm confused as hell</TD></TR></TABLE>
did you check your tps
Old Jan 4, 2007 | 07:46 PM
mrmckie's Avatar
Default Re: (boost'd_crx)
na..might have to chk that out.
sorry about jackin ur thread wong
93grayeg
10
Jul 30, 2011 11:35 AM
w0ng_sta
Jan 1, 2007 11:32 AM
boostinh22
Nov 29, 2005 11:15 AM
96civich22
Feb 12, 2005 05:24 AM
ScubaStevo80
Jan 24, 2003 06:26 PM
