Spoon head gasket??
Old Dec 31, 2003 | 09:38 PM
spnfed's Avatar
Default Spoon head gasket??
Has anybody use one before? If so is it even worth it for a B16?
Old Dec 31, 2003 | 11:14 PM
mastarolla's Avatar
Default Re: Spoon head gasket?? (spnfed)
i believe it bumps compression a tad and ive heard no complaints about it at all...figure out the specs on the mugen as well because i believe the two have a little bit different effects on compression...one might suit your needs better than the other
Old Jan 1, 2004 | 04:10 AM
Jimmy's Avatar
Global Moderator
Default Re: Spoon head gasket?? (mastarolla)
bump..I'd like to see specs between the two also.
Old Jan 1, 2004 | 09:27 AM
Padawan's Avatar
Darth ModerVader
Default Re: Spoon head gasket?? (USDMDC2)
Spoon = .45mm
Mugen = .47mm
Either will provide basically the same bump in compression (roughly +.3 points), though the Mugen appears to be the more widely-used of the two. It's also worth mentioning that a thinner gasket will retard cam timing slightly.
Old Jan 1, 2004 | 01:35 PM
spnfed's Avatar
Cool, maybe i'll look into the mugen one.
Old Jan 1, 2004 | 08:59 PM
yeer's Avatar
Default Re: (spnfed)
running spoon one and no problems
Old Jan 1, 2004 | 09:03 PM
spnfed's Avatar
Default Re: (yeer)
I just want to up the compression a wee bit. I'm building a mostly stk B16A for my girlfriends delsol. It's gotta be really reliable.
yoorang
16
Nov 12, 2006 04:51 PM
lePetitePrince
Jan 15, 2003 06:04 AM
snake01
Nov 13, 2002 03:26 PM
Spoon_Civic
10
Jan 22, 2002 09:39 PM
