another iacv problem
Old Dec 31, 2003 | 02:21 PM
92civeg's Avatar
Default another iacv problem
Recently i replaced a coolant hose that connects my iacv to an fitting under the throttle body. I took the damaged hose off and up to a local parts store where they gave me a replacement hose. I came back put the new hose on, filled and bleed the coolant and now every now and then my throttle seems to stick a little. Ill just be driving and when i come to a red light and push the clutch in my idle will stick around 2000 rpms or whatever i was last driving at...I thought about just cleaning it but i only had the hose off for about 15 min so how dirty could it have got? Any input is greatly appreciated
thanks
Old Dec 31, 2003 | 10:19 PM
92civeg's Avatar
Default Re: another iacv problem (92civeg)
ttt
Old Jan 1, 2004 | 01:24 AM
Katman's Avatar
you might want to clean your TB out with carb cleaner. Im guessing yout TB is all gunked up around the butterfly/throttle plate.
Old Jan 1, 2004 | 04:24 AM
B18C2_sedan's Avatar
Default Re: another iacv problem (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">you might want to clean your TB out with carb cleaner. Im guessing yout TB is all gunked up around the butterfly/throttle plate.</TD></TR></TABLE>
Make sure to bleed the collant several times.
Old Jan 1, 2004 | 11:52 AM
c jackson's Avatar
threes
Default Re: another iacv problem (B18C2_sedan)
ya check the tb, and maybe even your throttle cable needs to be replaced
Old Jan 1, 2004 | 11:55 AM
blah13's Avatar
Default Re: another iacv problem (c jackson)
When the idle does stick, can you pull up on your gas pedal and bring it back down? Mine did something like that and I just greased every moving part on my gas pedal and greased the cable, then greased what I could on the tb. If it sticks and you cant change it...hit that tb.
Old Jan 1, 2004 | 09:09 PM
92civeg's Avatar
Default Re: another iacv problem (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">When the idle does stick, can you pull up on your gas pedal and bring it back down? Mine did something like that and I just greased every moving part on my gas pedal and greased the cable, then greased what I could on the tb. If it sticks and you cant change it...hit that tb.</TD></TR></TABLE>
no when the idle sticks pulling up on the pedal doesn't change it, but if i give it a slight rev it corrects itself..Ive bleed the coolant 2 more times and its still happening..i guess my next step it to check the tb.
does the problem sound like it has anything to do with the iacv?
thanks
ska24
K Series
May 20, 2019 07:22 AM
rick_rabies
May 5, 2009 07:45 AM
93formula
10
Aug 14, 2007 07:12 PM
prelude_93vtec
Jun 26, 2007 06:30 AM
another_import
Oct 18, 2002 09:23 AM
