Speedometer doesn't go over 84
Old Nov 7, 2009 | 01:29 PM
the 1 and only jj's Avatar
Default Speedometer doesn't go over 84
Got a swapped 93 del sol si with b16a2, notcied the other day that when i hit 84 the speedometer stopped moving. Its been awhile since i've gone that fast but it has never done it before. I thought it might be the clutch slipping but I'm able to floor it in all gears with out any slippage as well as i tested it out a bunch of times and am able to still accelerate even though the speedometer doesn't show it. any one have any ideals as to why this is happening?
Old Nov 7, 2009 | 07:07 PM
locash's Avatar
Default Re: Speedometer doesn't go over 84
Because if it gets to 88mph, the car will break the time/space continuum.
Sounds like a VSS problem to me.
Old Nov 7, 2009 | 10:31 PM
spawn_616's Avatar
open bonnet,remove three bolts,replace vss and voila,or maybe urs governed incorrectly
but car is to old to be limited
Old Nov 8, 2009 | 05:16 AM
KWayRacing's Avatar
Does your odometer continue to work at 84mph?
Old Nov 9, 2009 | 06:55 AM
odometer still works at 84+
Old Nov 9, 2009 | 07:00 AM
jjspec's Avatar
Needs more powa!
j/k I wouldnt think the VSS would stop at 84. The speedo face could be not flat letting the needle drag on the face.
Old Nov 10, 2009 | 12:49 AM
fastrxu's Avatar
I agree with locash
You should check your flux capacitor
Dustinninja
Transmission & Drivetrain
Nov 12, 2017 03:56 PM
Bipolarcivic
12
Mar 27, 2016 03:34 PM
delsoldriver96
10
Jul 31, 2013 09:38 AM
kaboom954
Feb 22, 2010 03:17 PM
dr_liver_bones
16
Dec 7, 2005 07:38 PM
