speed sensor input voltage
Old Jun 8, 2005 | 04:29 PM
dfoxengr's Avatar
Default speed sensor input voltage
if i am reading my helms correctly vss input is 0-5 v?
can anyone confirm this?
would 12v burn up the motor in the odometer?
Old Jun 9, 2005 | 04:33 AM
EE_Chris's Avatar
Default Re: speed sensor input voltage (hybridvteceg)
VSS output is a 0-5v pulsed DC waveform.
Would 12v burn up the odo motor - probably.
Old Jun 9, 2005 | 05:28 AM
dfoxengr's Avatar
Default Re: speed sensor input voltage (EE_Chris)
so it is regulated by faraday's law, and at lower speeds smaller v is outputted, and higher speeds more v correct?
Old Jun 9, 2005 | 06:48 AM
EE_Chris's Avatar
No - it always puts out a 0-5v waveform - its the frequency that increases to indicate a greater vehicle speed.
Old Jun 9, 2005 | 06:57 AM
dfoxengr's Avatar
oh ok, could you simulate it with (3) 1.5v batteries?just curious so i know im understanding it right
Old Jun 9, 2005 | 07:26 AM
EE_Chris's Avatar
It wouldn't be accurate. If the gauge has an integrator built into it, which takes that pulsing DC and turns into a voltage that is proportional to it, then the fact that it never reached 5v will cause inaccuracy. You would also need a switch to simulate the on/off states, but your hand couldn't keep up that fast.
fcm
Nov 4, 2014 05:32 PM
Rat Rod
Nov 18, 2010 04:02 PM
aziaticvang
Jan 13, 2008 06:35 PM
FGride
Feb 18, 2006 09:37 AM
cj7420
Sep 5, 2001 06:46 PM
