Speed gear removal ?.
Old May 2, 2005 | 06:56 PM
HT Chaplain's Avatar
Loved
Default Speedometer gear removal ?.
I tried searching and didnt come up with anything. Im trying to get my speedo gear off my y1 diff and i took it to 4 machine shops and no body wanted to give it a try because they thought they would break it. Whats the best way to remove this? do I have to remove the diff. bearing as well or can I save a step and just remove it over the bearing?
(Come on HT dont fail me now)
Old May 2, 2005 | 07:24 PM
Jim Truett's Avatar
Default Re: Speedometer gear removal ?. (HT Chaplin)
The bearing needs to be pulled.
Old May 3, 2005 | 08:19 AM
Loved
Default Re: Speedometer gear removal ?. (Jim Truett)
TTT
Old May 3, 2005 | 09:38 AM
Kataku2K3's Avatar
Easiest way, pull the passenger side diff bearing, heat the speedo gear with a blow torch (evenly), then simply slide it off with a pair of pliers. It's not too difficult...
Old May 3, 2005 | 12:55 PM
Loved
Default Re: Speedometer gear removal ?. (Kataku2K3)
Great info! keep them coming if you got anymore suggestions. Thanks!
Old May 3, 2005 | 02:27 PM
95lstegman's Avatar
get a gear puller and put a giant bolt into the end of the diff. pull the bearing, then pull the speedo gear. takes about 5 minutes to do. then put the speedo gear in an oven at 350 for 8-10 minutes and put the diff on the counter. take out the gear and it takes only a few taps of a mallet to pop it onto the diff.
Old May 3, 2005 | 03:26 PM
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Easiest way, pull the passenger side diff bearing, heat the speedo gear with a blow torch (evenly), then simply slide it off with a pair of pliers. It's not too difficult...</TD></TR></TABLE>
Well I just got done doing this and it took like 2 minutes. Cut the bearing off with a cutting torch and heated up the speedo gear and it pretty much just fell off with some pliers. Thanks!
aut0tek
Transmission & Drivetrain
Sep 10, 2013 09:08 PM
Destructive-
Jan 29, 2008 08:55 PM
