Spark plug voltage - any techs here?
Old May 3, 2002 | 08:19 PM
dbman96's Avatar
New User
Default Spark plug voltage - any techs here?
Hey - looking for some input on this:
my GSR's been running pretty rough for the last few weeks (rough idle; sounds a little like it's missing when I accelerate under light-medium load) and I'm getting a bit sick of it so I figured I'd do something. I've got a SUN engine analyzer at work so just for kicks I hooked up the inductive pickup and watched the spark voltage on each cylinder.
Cylinder 1 was around 12-15 kV and cylinders 2-4 were each anywhere between like 7 and 10 kV. I'm not sure what the voltage is supposed to be, but the fact that it's irregular between plugs makes me think something's wrong.
Old May 3, 2002 | 09:31 PM
Rocket's Avatar
Default Re: Spark plug voltage - any techs here? (dbman96)
Have you recently spray washed your motor?
Old May 3, 2002 | 09:37 PM
dbman96's Avatar
New User
Default Re: Spark plug voltage - any techs here? (Rocket)
No sir
Old May 3, 2002 | 10:11 PM
Rocket's Avatar
Is it missing at idle too? Can you isolate it to individual cylinders?
Old May 3, 2002 | 10:55 PM
dbman96's Avatar
New User
I can't trace the miss; it seems to idle without missing but under moderate load I can hear it start to sound really irregular... I know my dis. cap and rotor are well past due for replacement but I'm also suspecting I could have a leaking head gasket messing with my compression or worse on a couple cylinders (engine temp seems to randomly 'spike' to high and then drop down to low again - never stays hot but I've got a huge fluidyne on there).
Old May 3, 2002 | 11:04 PM
Rocket's Avatar
Check for missfires by hooking up a timing light to a plug wire and shoot the flashes at your hood and see if that cylinder is firing consistantly. You can also throttle the engine a little while your doing this to see if it happens at throttle.
lsvtechatchy
Jul 26, 2010 08:39 AM
dointhemzs
Sep 7, 2008 07:09 PM
DoHcZC91si
Aug 31, 2008 09:34 PM
boostede46
Apr 9, 2008 03:06 PM
_Endless_
Aug 16, 2002 11:42 PM
