spark plug question ... what does this mean
Old Jan 10, 2003 | 09:14 AM
respectblades's Avatar
Default spark plug question ... what does this mean
ok my spark plug tips are white...
the porcelain is black
am i running rich or lean
and does this mean i'm having denotation
Old Jan 10, 2003 | 09:39 AM
Desslok's Avatar
Default Re: spark plug question ... what does this mean (respectblades)
Do you have pics?
White tips usually mean lean. For detonation, you will usually have blistering/specks on the ceramic insulator portion.
Old Jan 10, 2003 | 09:49 AM
Default Re: spark plug question ... what does this mean (sp)
i'll try and get some pics up later
how can i get it to run richer if that is the problem
Old Jan 10, 2003 | 09:53 AM
Desslok's Avatar
It depends on if you have vaccuum leaks, or if you have adjustable FPR, SAFC, etc. But a good way is to check your timing, retard if necessary. Also make sure you have correct heat range plugs. May want to check fuel pressure if your unsure or change fuel filter if it has been a while.
Old Jan 10, 2003 | 10:02 AM
serious's Avatar
since the cermaic of the plug is black, i'd guess that the white you're seeing on the tip is ash. i'd have to go the opposite direction and say you're running rich. check out these links for help on reading your spark plugs:
http://www.motocross.com/motoprof/mo...lug2/plug2.htm
http://www.buckeye-illinois.com/sparkplugs.htm
Old Jan 10, 2003 | 10:12 AM
Default Re: spark plug question ... what does this mean (serious)
ok i see a pic on there that looks just like mine
i'm running to rich
any techniques i could use to correct this
Old Jan 19, 2003 | 09:14 AM
nfn15037's Avatar
i'm running to rich
You cant tell if you are running rich or lean by the color of your sparkplugs, since when your not on it, the ECU is running in closed loop mode, ie-its taking readings from the O2 sensor to correct the A/f ratio. Best bet is take it to a dyno with a wideband O2.
Old Jan 19, 2003 | 02:40 PM
serious's Avatar
Default Re: spark plug question ... what does this mean (nfn15037)
i'm running to rich
sure you can tell if you're running rich or not, it simply won't tell you what part of the if system is to blame, whether it's the injectors, o2, ecu, etc.
it also may not mean you're always running rich, lean, whatever, but it is saying that everything is not right and at least part fo the time you're rich/lean.
fly_high_gsr
Engine Management and Tuning
Feb 3, 2009 10:25 AM
92CivicSiR2
Sep 22, 2004 01:30 PM
RTW DC2R
Mar 13, 2004 09:34 PM
TORQUE MONSTER
May 22, 2003 12:00 PM
JDM R98
Aug 16, 2001 06:32 PM
