spark plug hole stripped?
Old Oct 22, 2008 | 05:24 AM
GSR_hatch936's Avatar
Default spark plug hole stripped?
alright i just got this motor built and i just finished dropping it in yesterday and i went to put the spark plug wires in and the 2 in the middle seemed to sit higher the piston 1 and 4.? Would the hole inside be stripped? I tighten them as hard as i could and then untighten them and checked for shavenings and there was none? Could i just turn the car on with them 2 higher??? Its a b20b block with ls head.
Old Oct 22, 2008 | 08:15 AM
Default Re: spark plug hole stripped? (GSR_hatch936)
No input?
Old Oct 22, 2008 | 11:32 AM
turboSEGS's Avatar
you put your spark plugs in as tight as you could...?
Old Oct 22, 2008 | 01:23 PM
Default Re: spark plug hole stripped? (turboSEGS)
I did know and they sit almost right. But i dont remember ever having to tighten spark plugs that hard.. I guess it will work for now.. hope so.
Old Oct 23, 2008 | 12:35 AM
turboSEGS's Avatar
you never want to over tighten them im sure you know that good luck
Old Oct 23, 2008 | 09:36 AM
DSRxCandyh2bEG's Avatar
make sure the washer on the plugs threaded side isn't sitting crooked, if it is, it will feel like the SP is all the way down but it actually isn't.. don't over torque the SP's either. you really don't wanna strip the head...
I did the same thing a long while back and instead of stripping the head, my threads broke off the spark plug and were lodged inside the head, luckily i just used a long flat head screw driver and was able to spint it out... lucky me
b20bFourDoorCivicLX
Mar 16, 2012 10:26 PM
busta7777
Feb 9, 2011 04:01 PM
careawholelot
Apr 29, 2004 03:42 PM
sfr4dr
Jan 19, 2004 03:53 PM
nek0
Jul 22, 2003 04:07 AM
