Spark Plug cables pop off?
Old Dec 25, 2003 | 09:48 PM
ACRXGuy's Avatar
Default Spark Plug cables pop off?
I cannot figure out the reason for this? I am thinking its blowby from the spark plugs. Any other theories? I am using iridium plugs with 8.5 MSD plug wires.
Sal
Old Dec 25, 2003 | 10:23 PM
blah13's Avatar
Default Re: Spark Plug cables pop off? (ACRXGuy)
How old are the wires? Perhaps the little "lip" on the inside has worn and its not holding on well and simple vibration is loosening them? Or are they literally popping off?
Old Dec 26, 2003 | 01:42 AM
Mista Bone's Avatar
D Tranny Guru
blowby past the rubber spark plug seals in the valve cover.
Old Dec 26, 2003 | 05:39 AM
fulldragcrx's Avatar
Default Re: Spark Plug cables pop off? (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">blowby past the rubber spark plug seals in the valve cover.</TD></TR></TABLE>
you got it...
Old Dec 26, 2003 | 12:24 PM
sa21199's Avatar
Default Re: Spark Plug cables pop off? (fulldragcrx)
Make sure the rubber boot on the wire is ok first. Same thing happneed to me... and the rubber on the wire was old and messed up so it wouldnt hold
Old Dec 26, 2003 | 01:04 PM
mattssi's Avatar
Old Dec 26, 2003 | 04:07 PM
smokey2.0's Avatar
that's true, but how about when they pop out from the distributor cap?
Old Dec 26, 2003 | 06:35 PM
Default Re: Spark Plug cables pop off? (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
that's true, but how about when they pop out from the distributor cap? </TD></TR></TABLE>
OEM parts wont do this, as long as you press it in untill a click if felt .
Old Dec 26, 2003 | 06:43 PM
DVS_EF's Avatar
zip tie them... works good!
Old Dec 26, 2003 | 06:44 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">
OEM parts wont do this, as long as you press it in untill a click if felt .</TD></TR></TABLE>
i'm using OEM b16 spark plug wires, they do pop off once in a while!
smokey2.0's Avatar
Default Re: Spark Plug cables pop off? (dvsEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvsEF &raquo;</TD></TR><TR><TD CLASS="quote">
zip tie them... works good! </TD></TR></TABLE>
i seen a lot of guys doing that lately, looks getto but it work
Old Dec 26, 2003 | 07:45 PM
94dxt's Avatar
it's probably the Crappy msd wires mine started donig it once I put them on and I don't have any blowby past the washers
Old Dec 27, 2003 | 08:01 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Spark Plug cables pop off? (94dxt)
MSD wires and MSD cap, never had a wire pop off yet in 3 years.
ekferio
Aug 7, 2008 12:06 PM
CONTROLLED CONFUSION
Nov 8, 2007 03:23 PM
crvtt717
May 11, 2007 04:24 AM
808State
Jan 6, 2005 07:56 PM
BigDawwg6969
Apr 27, 2004 06:28 PM
