single spark plug indicates a problem, but what?
Old Sep 23, 2013 | 03:56 PM
EG6 Love's Avatar
Default single spark plug indicates a problem, but what?
I have pictured 2 different sets of plugs pulled from my boosted 500whp GSR running on e85. As you can see cylinder #1 has repeatedly fouled.
I have already moved the fuel injector to #2 with new plugs and the the bad plug remained #1.
compression test results were 205 psi across the board.
Does anybody know what is causing this?
Thanks, Doug
Old Sep 23, 2013 | 05:26 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: single spark plug indicates a problem, but what?
Does your ems have individual fuel trims for each cylinder? If the trim is off on cyl1 then that would explain the constant fouling. Did you relocate the bad plug to another cylinder or put a fresh set in after moving the injector?
The only other options are a wiring issue or the injector drivers in the ecu are acting up
Old Sep 24, 2013 | 08:18 AM
EG6 Love's Avatar
Car is tuned with Crome but I am unaware whether trims are adjusted individually. Would e85 cause a plug to foul out black?
I did install new plugs when I moved injector.
Old Sep 24, 2013 | 08:34 AM
Turbo-LS's Avatar
Looks like could be a little oil. If you moved injector around and it's still on same cylinder it's a wiring issue or oil issue. Pull manifolds off see in valve seals are leaking. Are you running stock PCV ?
Old Sep 24, 2013 | 08:56 AM
EG6 Love's Avatar
I was suspecting a valve seal. I have a breather and catch can. Only the 2 "oil drain ports" on the back of the block and the small port above the plugged off port go to the catch can. How can I test for a bad valve seal?
Old Sep 24, 2013 | 09:02 AM
wantboost's Avatar
Who is Mr Robot?
You can't. But while the car sits the seal will keep leaking to a point. So it will be easy to see
Old Sep 24, 2013 | 09:11 AM
EG6 Love's Avatar
That's how I've always determined a bad valve seal but my car doesn't smoke at all that I can see. I'm suspecting that the leaking may only be occurring during high load high boost situations and I'm not paying attention behind me when I'm foot to the floor haha.
Possible?
slowwcivic
May 25, 2011 06:18 AM
jvillagran2000
15
Dec 2, 2008 02:03 PM
aziaticvang
Jul 19, 2008 11:10 AM
senbei
Jul 1, 2003 03:19 PM
JSpecwest
Jan 4, 2002 01:23 PM
