How to check for fuel in a cyl?
Old Aug 3, 2002 | 01:50 AM
Kamin's Avatar
Default How to check for fuel in a cyl?
um ok.
i was getting some gas about an hour ago and well the car was idling horrible
so i figured it was an unplugged spark plug wire or a fouled plug
changed plug, checked wires. all cyl are getting spark
cyl 1, 2, and 3 **** the idle up when i remove the spark plug wire. there is an audible spark tho.
cyl #4 does not change the idle. the idle sounds off. it shakes the car a little. there is an audible spark and visible spark when the wire is removed.
that narrows it down to fuel
how do i check to see if a specific cylinder is getting fuel? please help asap.
Old Aug 3, 2002 | 02:01 AM
Kamin's Avatar
Default Re: How to check for fuel in a cyl? (KAMiN)
looks like my injector is toast
no resistance with an ohms test between the terminals.
Old Aug 3, 2002 | 02:06 AM
sparkz's Avatar
pull your plugs right after cranking it. if you dont smell fuel, its probably gone. check to see if your injector plug is in all the way.
Old Aug 3, 2002 | 02:08 AM
Kamin's Avatar
i just checked the resistance on all the injectors
they all have a resistance
the #4 cyl dosent
and the harness has 12 volts all the way across.
looks like we have a winner
a toasted injector.
Old Aug 3, 2002 | 12:08 PM
Kamin's Avatar
just to update
i swapped the injectors this morning (like from cyl 3 to 4) and the problem moved to cyl #3
looks like a trip to autozone
injector 1 ME 0
turboedek96819
Apr 5, 2015 06:14 PM
VTecLude1994
Apr 16, 2007 04:46 PM
virusiidx
Jan 18, 2005 10:11 AM
951dc5
Nov 26, 2004 05:33 PM
StRacer
Aug 10, 2003 09:27 PM
