is this sound from my car normal....
Old Jan 21, 2002 | 07:02 PM
Halive's Avatar
New User
Default is this sound from my car normal....
My car makes a wierd sound when it idles, or at least I think it sounds wierd. It just sounds really tinny I really dont know how to describe it other than that. Its not a knocking sound(valves or aything) or anything. Is this normal for my car or cars like it??? Also when the car just sits and idles the air conditioning keeps turning on and off. I have underdrive pulles would that be causin the problem?? Thanks for the advise.
Troy
Old Jan 21, 2002 | 07:05 PM
rainforest's Avatar
Default Re: is this sound from my car normal.... (Halive)
well how old is your xar it could be you ac compressor tring to seize on you.
Old Jan 21, 2002 | 10:44 PM
LoStreet94's Avatar
Default Re: is this sound from my car normal.... (rainforest)
The a/c compressor clutch is suppose to cycle on and off. Thats how the system works. Rule of thumb: maybe 3-5 times a min. Fast cycling could also mean that you are low on freon. L8S
Old Jan 22, 2002 | 04:10 AM
sohc_boy's Avatar
not sure about the sound cuz u really don't give any description of it. but at idle u can some times hear a funky resonation through your cold air intake. its not a knocking noise and it isn't a sucking noise its a kinda wierd sound.
Old Jan 22, 2002 | 01:12 PM
type autox's Avatar
New User
Default Re: is this sound from my car normal.... (sohc_boy)
I have a short intake on my car and it rings at idle. its cool, you can hear it from 15 yards! sounds like the sustain on a large bell.
Old Jan 22, 2002 | 01:15 PM
Spade's Avatar
Default Re: is this sound from my car normal.... (type autox)
ever have the a/c clutch try and engage while at WOT!?! screeaaaaaccchchchhhhh. (Doh, hit a/c button )
Old Jan 22, 2002 | 02:26 PM
iceburgslim's Avatar
If you only hear this noise after a cold-start, it is probably just piston slap. It's normal on Civic's...Honda even issued a bulletin saying that it's normal. I hope this helps. Later!
jrock1234
Jun 4, 2012 12:26 PM
pinecone
10
Mar 26, 2006 08:27 AM
NerveAgent
15
Jul 21, 2005 09:56 PM
User 5426
Jun 19, 2005 08:06 AM
tachman
Apr 4, 2003 04:30 PM
