Detonation problem?
Old Jan 21, 2002 | 02:12 PM
PolySquared's Avatar
Default Detonation problem?
My "check engine" sensor popped up and I decided to take my car to the dealership to get that checked. They said the problem is my catalyic converter. When my muffler shop installed my cat, it was welded onto my exhaust. Therefore, there is a detonation problem? (said the dealer) They said I needed a new cat. Is this true?
Old Jan 21, 2002 | 02:14 PM
martini's Avatar
Default Re: Detonation problem? (PolySquared)
I'd go get a second opinion for sure.
Old Jan 21, 2002 | 02:46 PM
HaUTSaauce's Avatar
New User
i dont know about this one like the guy above me said i would get a second opinion
Old Jan 21, 2002 | 04:02 PM
Duck Sauce's Avatar
Default Re: Detonation problem? (HaUTSaauce)
Sounds like he's trying to milk you for money.
Old Jan 21, 2002 | 05:02 PM
Default Re: Detonation problem? (www.s4-mtm.com)
Ok, got back from the dealership and it says:
"FOUND CODE P0420 CATALYST DETERIORATION - FOUND B PIPE WELDED TO C"
I have a Apexi Dunk cat back and I can see the welding. The bolt on section has been cut off and being welded onto my carsound high flo cat. Do I need a new cat and exhaust? I am planning on just using my stock cat.
[Modified by PolySquared, 2:02 AM 1/22/2002]
Old Jan 22, 2002 | 03:27 PM
Ok, never ever going to a dealership again! I went to another car shop and all they did was reset. Its just the 02 sensoring not recognizing enough back pressure because of my mods. Bad thing is, the sensor may pop again in a couple of months.
Old Jan 22, 2002 | 03:48 PM
97accordex's Avatar
If its stock cat on hi flo exhaust and header and intake you may be getting some unusual exhaust gas flow patterns that are popping the sensor. Your header, intake, and exhaust are trying to flow more exhaust gas but the stock cat is kind of a bottle neck.
xjohnx
Sep 26, 2006 06:29 PM
89sih22a
May 30, 2005 12:03 PM
94CivicSi
Jun 26, 2002 05:39 PM
93delsol
Apr 4, 2002 01:03 PM
JDM-FREAK
Feb 12, 2002 05:13 PM
