Solid steel bushings with Spherical bearings
These are on a DC2 / R front lower control arm.
Close up of Bearing in bushing.
Each bushing holds 2 bearings, one on either side. this will make it a true spherical bearing suspension and minimize and or rid off any twist in the control arm. At the same time the steel bushings will eliminate caster changes for the outside corner wheel.
Opinions are expected, bad or good.
Keep in mind this is the prototype.
Modified by Renegade at 12:39 AM 9/9/2005
n0rmaL
Southern California
11
Apr 23, 2012 07:31 AM
block131
Suspension & Brakes
Dec 23, 2009 07:17 AM
daigo
Apr 27, 2005 07:01 PM
