FJO injector driver wiring
Old Jul 9, 2008 | 05:55 PM
Mikey3000's Avatar
Default FJO injector driver wiring
I have the unit that has 10 wires + 1 ground and 1 power. The wiring diagram says the white wire should go to all of the injectors. So how do I run one wire to four separate wires?
Another thing; can I utilize the dead end plug (the one with 8 yel/blk wires on the driver's side) to simplify any of the wiring?
Old Jul 9, 2008 | 06:16 PM
IN VTEC's Avatar
Default Re: FJO injector driver wiring (Mikey3000)
You find the four ylw/blk wires that share a common 12VDC+ source from that distribution block and tie those four with the white/whatever wire on the output harness of the FJO driver.
The best placement for us in the Civic would have been on the frame rail or enclosed in a box behind the headlight, but the manufacturer specifications only allow for an ambient temperature maximum of 185 degrees Fahrenheit, and I was worried that vibration would hurt the unit eventually if I mounted it to the frame rail. So, it's currently sitting next to the ECU until I can work out a better solution.
Old Jul 9, 2008 | 06:50 PM
Turbo-charged's Avatar
Default Re: FJO injector driver wiring (IN VTEC)
i think its much cleaner to run a whole new injector harness. from your ecu the signal wires are going to go to the driver...and from the driver to the injectors.......so it just makes sense to run your power wire (split to 4) along with the signal wires. i ran a 6 pin DTM connector on my old set up right by the throttle body so i could pull the head/intake off with out having to unplug the injectors individually.
Old Jul 10, 2008 | 04:30 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You find the four ylw/blk wires that share a common 12VDC+ source from that distribution block and tie those four with the white/whatever wire on the output harness of the FJO driver.</TD></TR></TABLE>
so 4 out of the 8 that are on that dead end plug are 12VDC? so i need to probe to find those, then i can hook the white to those?
Old Jul 10, 2008 | 06:42 AM
IN VTEC's Avatar
Yes. Just run a continuity test from each of the ylw/blk wires in the each of the injector connectors.
Old Jul 10, 2008 | 02:47 PM
Mikey3000's Avatar
i just checked continuity between the yel/blk of the dead end plug and each of the injector plugs and there was continuity between all of them. so each wire doesn't correspond with a certain injector, one wire powers all of them. does this make sense? how do i proceed to wire this sumbitch?
Old Jul 10, 2008 | 07:28 PM
call me tomorrow and i can walk you through it. your trying to do it the hard way
Old Jul 10, 2008 | 11:00 PM
V-SPEC 1's Avatar
I don't think you check it right. when I put my oem injector driver, each of those yel/blk wires from the injectors have thier own yel/blk wires on the dead end plug. I am now going to install this fjo driver same as yours w/ 10 wires on one side and 8 wires on the other and I also need to know how to install this bad boy. Joe, can you please make a "how to install fjo injector driver" specially the one we have w/c are the 10 wires w/c are more difficult to do. thanks in advance. And maybe we can make that a "sticky" on here for people in the future.
Old Jul 11, 2008 | 04:17 AM
Mikey3000's Avatar
Default Re: FJO injector driver wiring (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">call me tomorrow and i can walk you through it. your trying to do it the hard way </TD></TR></TABLE>
i thought about doing that yesterday. i'll do that today though, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you check it right. when I put my oem injector driver, each of those yel/blk wires from the injectors have thier own yel/blk wires on the dead end plug. I am now going to install this fjo driver same as yours w/ 10 wires on one side and 8 wires on the other and I also need to know how to install this bad boy. Joe, can you please make a "how to install fjo injector driver" specially the one we have w/c are the 10 wires w/c are more difficult to do. thanks in advance. And maybe we can make that a "sticky" on here for people in the future.</TD></TR></TABLE>
mine has 11 wires total not 10 and 8. it has 6 wires on the ECU side and 5 on the injector side.
Old Jul 11, 2008 | 03:51 PM
DaveF's Avatar
try this
Old Jul 11, 2008 | 11:21 PM
V-SPEC 1's Avatar
Default Re: FJO injector driver wiring (DaveF)
I have the older version fjo driver right before this one that dave posted. Dave, can you please help me figure out how to wire the older version? or anyone? I really appreciate the help. Click on the link and download the manual for the older version. There's so many wires to hook up, I"m confused.
http://www.fjoracing.com/produ...g.pdf
Old Jul 12, 2008 | 04:24 AM
DaveF's Avatar
Default Re: FJO injector driver wiring (V-SPEC 1)
after writing all the crap out, i think it would be alot cleaner to just build a new injector harness LOL
Old Jul 12, 2008 | 08:32 AM
V-SPEC 1's Avatar
Dave for president thank you sir
Old Jul 13, 2008 | 07:27 AM
Turbocivic94's Avatar
Dave is correct. Its much easier to build a harness with old FJO box. Thats what I did with my old harness.
Old Jul 13, 2008 | 07:57 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">Dave for president thank you sir </TD></TR></TABLE>
thanks, let me know how/ if it all works out for ya
HT Chaplain
Welding / Fabrication
Jun 14, 2010 08:50 AM
iheartamy
Dec 23, 2006 08:43 AM
Mr. Vapor
May 7, 2005 01:03 AM
FourthGenHatch
Sep 2, 2003 04:20 AM
HKSone
Jul 10, 2003 04:53 PM
