SOHC BUILD tech help
Old May 24, 2003 | 07:53 AM
Boltz's Avatar
Default SOHC BUILD tech help
TIA, Benson at garbage kwai sent my motor to the grave (he broke my oil pressure sensor(dunno if the blowing of the motor and OPS were related)) so now I have the option of rebuilding it or buying a new motor. Im leaning towards having Dave from the WhipFactory build it for me. I was thinking CP pistons, Eagle Rods, ARP head studs, Rod bolts, new bearings, and crank balance. My questions are should i
1. Spend 1500-1800 on a built bottom end?
2. IF yes, should I use the CP pistons? (I hear they are really good, but have also heard they are more for race cars, my car is a daily driver.)
3. Spend the money on another stock engine?
Old May 24, 2003 | 07:54 AM
Boltz's Avatar
Default Re: SOHC BUILD tech help (Civic420)
Thanks
Old May 24, 2003 | 10:37 AM
Boltz's Avatar
Old May 24, 2003 | 11:44 AM
RyanEJ8's Avatar
Rebuild! I don't know much about the CP pistons, I am using SRP's for my soon to be built motor.
Old May 24, 2003 | 03:05 PM
Boltz's Avatar
Default Re: SOHC BUILD tech help (RyanCivic2000)
If i were you i would look into the CP pistons Ryan. The reason I am considering them is that they dont make the damn piston slap like JE SRP pistons. The material they are made of doesnt expand as much as the JE SRP, meaning they should be easier on your block. They are also much lighter than the JE SRP pistons.
TAI
Old May 24, 2003 | 04:53 PM
rabbid's Avatar
Hey as far as pistions go I would look into TRW forged pistions. My brother used them in a rebuild an he never had a problem with them at all. At the time they were cheaper than other manufactuers but just as good. he used nitrus on the set up and never had a problem. { quite a few of them today }
Old May 25, 2003 | 07:56 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic420 &raquo;</TD></TR><TR><TD CLASS="quote">If i were you i would look into the CP pistons Ryan. The reason I am considering them is that they dont make the damn piston slap like JE SRP pistons. The material they are made of doesnt expand as much as the JE SRP, meaning they should be easier on your block. They are also much lighter than the JE SRP pistons.
TAI
That design is more for a race car with over 400-500whp. Not my daily driver.
Old May 25, 2003 | 09:28 AM
Boltz's Avatar
yea ive heard rumors that they arent suited for daily driven cars but those are just rumors... thats why the post started. i wanna know why. I can get a pretty good deal on them
97accord_R
Mar 23, 2009 02:29 PM
hondadriver
Sep 30, 2006 02:58 AM
NXdelsol93
Jan 13, 2003 05:08 PM
CovertFI
May 23, 2002 11:34 AM
